Heads / Cam help please
Hello I have a 1999 ls1 that has an ls6 intake, headers, 80 injectors, boost a pump, p1 supercharger and the engine is otherwise stock, I'm currently making 530 rwhp with 10psi of boost, I would like to add a cam and heads that would get me to 700-750 rwhp with a stock bottom end and still be reliable and be driven daily on the street if that's possible, I know I'm going to get many opinions but look forward to hearing them all, thank you.
Pulley down, put in a good cam, get a real fuel system. E85 or pump plus meth should get you in the 650-700 area. I wouldn't risk expensive heads on a 20 year old motor. Guys have made 750+ with the stock block and 241's. P1 is like a T trim or 1500 at 1200cfm if I remember correctly. Might take a bit more to spin though but you should still see 650-700.
nzcars33 (02-08-2017)
