Oil catch can and Maggie S/C
Hello, does anyone have oil catch can on their Maggie S/C'd LS1, if so, any possible photos of the hose routing , I have seen there are 2 or 3 port catch cans , specifically Elite engineering brand, I ve read that a S/C's setup runs a check valve inline?, or is it just spliced into the factory PVC hose to Maggie S/C.
1998 LS1 Maggie MP112
30k miles
Thanks for any input
30k miles
the maggie does not need an additional check valve, it is always connected behind the TB and ahead of the blower so it never sees boost.
a catch can will help you keep the inter cooler core clean.
from PVC to the inlet on the catch can and the out to the SC like a normal install.
Thanks appreciate the input
