"Best Turbo for a stock C5"
No, not necessarily. I think it might come down to your tuners capabilities. what it makes on 94 octane and an a/a cooler before detonate begins. If he's happy with it then meth isn't necessary. If he wants to push the envelope then add meth.
sweet. fast cars are vegetarian drug addicts (E85 from corn, METHanol )
Thats an LS3 (6.2L), correct ?
(Although the Gen 4 aluminum L33 5.3 would be my budget 'gooder' engine )
Keep your eyes open for an L33 just in case to tuck away in the corner. This turbo stuff gets out of hand quickly. Lol. I got 2 solid years out of my ls1 at 565 RWHP and it was a blast.
Hey, whats the clutch to get, there's everything from the $500 LS7 clutch to the $1000+ Monster ones. Again, 99% street car, Might put some DRs on and run it down the 1/4 on occasion. what about the "rearend" ? bracing etc.
The clutch is beyond me. I've got a level 7 4L65e. Crawl up under it an see if it has a 3 rib differential. That's a big plus. A couple vendors sell trans braces which are always recommended.
Depending on which gear it has, you will probably find that it's cheaper to find a 3 rib differential with a 3.42 gear is quicker and cheaper to swap out than changing a corvette diff gear set. I couldn't believe the cost from a rearend shop in Chicago. My car came with 3.15's and I got a 3 rib diff from a low mileage 03 Z06 for around $550.
Then I was able to sell my 3.15's to a guy running 1/2 mile events to recoup some money
#34
I just want to get it all figured out so when I get my C5, it'll be easy, 2nd nature !
#35
[QUOTE=richincanada;1594213254]found this :
stock LS1. stock heads stock cam on 10 psi tuned on 87 octane. 60 injectors 340 fuel pump with hot wire kit.
Stock heads cam and 87? Im not buying that.
I have an STS setup w upgraded turbos, dead stock, 10# with meth and 534/556ft/#
#36
[QUOTE=StatmanRN;1594218216]I'm ALWAYS skeptical on dyno numbers when somebody posts a number which seems higher than normal. I always ask what is the cars ET. In lots of cases guys say they don't bring their car to the track. LOL
#37
I agree, that sounds like a very "generous" dyno.
534/556 seems more realistic...and "even" that is outstanding. Any track et/mph ?
#38
https://www.corvetteforum.com/forums...post1569978454
#39
A post from when I 1st put the turbo kit on my stocker.
crap, just checked and the 2015 Z06 is like 570/590RWHP
you made 525/577 ! what RPM do you shift it at ?
#40
The stock engine lasted about 4.5 years and was over 800rwhp at the end. It would have lasted a very long time at the 500rw power level. It got me into the 9s with a 6-speed.
I think with the stock cam, I typically shifted around 6200 rpm.
