What Exhaust are you high HP guys running?
Old 03-23-2017, 04:23 PM
GD-Zo6
GD-Zo6's Avatar
Default What Exhaust are you high HP guys running?
Hey Everyone,
So just curious what kind of exhaust you high HP guys are running or if you are running straight pipes?
My car is making a little over 800 now on pump gas and doing a few more upgrades and possibly going E85 which will put it into the 900's. My car has long tube header and x-pipe with no cats and the rear mufflers are stock but have the Muffler Mod. As of right now i am using the Lingerfelter LNC 2 step to launch. After using the 2 step a few times the welds inside the muffler crack and i keep getting them rewelded. So i thought about having my exhaust guy just remove the mufflers all together and just run straight pipe?
All advice and opinions are greatly appreciated on what I should be running.
Old 03-23-2017, 04:38 PM
Milan
Milan's Avatar
Whatever you like, exhaust really doesn't matter on these cars
Old 03-23-2017, 10:17 PM
trayack
trayack's Avatar
Depending on your combo it matters immensely. Going from a crappy 2.5 inch exhaust that necked down going by my tranny pan to a full 3 inch netted me a 100hp at the tire increase.
OP, I explained more in your C6 post.
- Travis
Old 03-23-2017, 10:24 PM
Rkreigh
Rkreigh's Avatar
I found the c5 exh systems rather limited and very expensive in the 3" high flow setups.
I'm going to take the plunge and hack the rear cubby and run a c6 z06 obx 3" exh. Upgrading to 3" down pipes to make running the numbers a bit easier.
Over 900 hp a 2.5 just won't cut it without excessive back pressure.
Old 03-23-2017, 11:59 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
Might be a C5 exhaust thing. The stock 2.5 NPP exhaust on a C6 can handle 1000 rwhp no problem.
This same thread was started in the C6 section so I assume it's a C6 the op is talking about.
Old 03-24-2017, 06:43 AM
Rkreigh
Rkreigh's Avatar
Nope, C5. LG, Stainless, and B&B all make nice quality systems that flow really well. But the 3" stuff is made out of unobtanium for me price wise so I scooped a sale on the OBX C6 system and will do a bit of cutting to the rear package tray to make room.
With the turbo cars, the exh DOES make a whole lot of difference.
The flapper systems flow more as they free up the muff when the wild switch is on.
I might also use flapper tips if mine is too loud, but with the turbos acting as a muff, I doubt it.
Old 03-24-2017, 09:42 AM
glennd
glennd's Avatar
I have 905 rwhp 416" F1A, 18psi
Kooks 1 7/8" headers, small 3" race mufflers in cat position ( to cut down on noise and resonance) 3" pipe to rear stock titanium (ZO6) mufflers. The car is fairly quiet during cruise and idle, no resonances under any conditions.
Very happy with set up.
Old 03-24-2017, 12:14 PM
Milan
Milan's Avatar
- Travis
100 whp from an axle back? lol GTFO of here with that noise
Anyone with headers already has dual 3" almost all the way to the back of the car. Having a few feet of 2.5" piping back there is not going to cause a restriction, especially not 100 hp worth
If I recall correctly, TCRuise went from something like bullets back to stock Ti's and gained like 9 whp. Catback is not a restriction on these cars.
Old 03-24-2017, 12:53 PM
SBCGENII
SBCGENII's Avatar
Turbo car.
Old 03-24-2017, 07:05 PM
Cordes Performance Racing
Supporting Vendor
Cordes Performance Racing's Avatar
Received 1,228 Likes on 775 Posts
kooks 2'', 3'' offroad x, 3'' b&b fusion I make 1165/1004
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old 03-24-2017, 07:46 PM
smokinstorm
smokinstorm's Avatar
I'm not sure if we'd be considered high horsepower or not in this day and age. We should make around 1100RWHP ultimately with our current setup. This started out like as a Kooks 3" mid section that we took apart in the middle where it slides together and welded in some 3" straight through race bullets and added turndowns. It's loud but honestly not as loud as most I heard clips of on here. Does it drone going down the road as it exits under the car? Well.....yeah but what do you expect? Quick startup clip of this exhaust on car. https://www.youtube.com/watch?v=92gT...ature=youtu.be
Old 03-24-2017, 08:00 PM
trayack
trayack's Avatar
At no point did I ever say it was an axle back swap. Its from the cast downpipe's of my GT30's. Also, as stated the previous exhaust necked down even farther than the 2.5 as it went by the Moroso tranny pan of my 4L80e which caused a huge restriction. So YES....when we switched to the new exhaust (back of the down pipes, to inlet of the preexisting mufflers) it did indeed net a gain of 100hp at the wheels, and dropped a full .35 off the ET.
- Travis
Old 03-24-2017, 08:11 PM
smokinstorm
- Travis
Turbo engines hate exhaust restrictions of any kind. No problem believing a full 2.5" exhaust system cost this engine combo a bunch of power.
Old 03-24-2017, 08:54 PM
Milan
Milan's Avatar
- Travis
You would think it's universally accepted that exhaust = axle back on these cars. Headers almost all come with mid pipes so if we were talking about headers then we would say that.
Your setup is an outlier, most people don't have your combo.
Old 03-25-2017, 01:30 AM
Turbo-Geist
Turbo-Geist's Avatar
2017 C5 of Year Finalist
The restriction related to the C5Z catback was confirmed long ago.
https://www.corvetteforum.com/forums...i-exhaust.html
https://www.corvetteforum.com/forums...6-muffler.html
To What Exhaust are you high HP guys running?
Quick Reply: What Exhaust are you high HP guys running?
