Magnuson Intercooler Upgrade Install
Got my upgrade KIT from Magnuson Two big boxes (1) parts (2) return carton. I already had blower removed so all I had to do was stick in box and get to UPS to ship to Mag so they can do their thing.
Anyone interested, here is the install documentation
http://www.magnacharger.com/pdf/manual05.pdf
Now I can install all the misc STUFF (heat exchanger, resorvior, fuel pump, wiring, etc) and wait for blower to arrive
[Modified by Black_Magic, 7:57 AM 3/20/2004]
[Modified by Black_Magic, 8:04 AM 3/20/2004]
Re: Magnuson Intercooler Upgrade Install (Black_Magic)
Neet! I can't wait to get mine installed. Here is a question: The intercooler and reservoir, is the fluid the same as your radiator fluid? Or is there some special fluid combo that circulates through the system. Might sound like a dumb question but I really don't know.
Re: Magnuson Intercooler Upgrade Install (steveNY)
[Modified by Black_Magic, 10:02 AM 3/20/2004]
thats great man!! At first I wasnt going to upgrade to the intercooler, I believe I may sometime in the near future now. Post your numbers after the install!!
The reason I was inquiring about the coolant was for when I put the car away in storage for the winter. I dont want parts bursting when the temps go below zero.
Whats with the valley cover
I was under the impression the only thing that Magnuson replaces on the blower is the top half of the manifold, it appears by looking at the valley cover that the whole manifold is going to be different.
And so much for my LS6 style cover
Re: Magnuson Intercooler Upgrade Install (runamuk)
They had a space problem fitting the intercooler fine inside the intake and still fitting the blower under the hood....so instead of going up, they went down (So the new valley cover is probably deeper than the stock one.
Waiting for my kit to get here from Magnuson on Monday or Tuesday.
The valley cover had groves for knock sensor wires & bolts are counter sunk to provide a little more space for cooler.
[Modified by Black_Magic, 4:21 PM 3/20/2004]
Water wetter is soap (surfactant) prevents cavitation in the cooler, promotes good heat transfer but does not prevent freezing. I think you need to add a mixture of antifreeze to the system to prevent freezing in cold climates. Best to check with MagnaCharger see what they say.
Re: Magnuson Intercooler Upgrade Install (comecorrect)
Is the coolant pump a FORD part?
MIKE
MIKE
George
Re: Magnuson Intercooler Upgrade Install (Operations)
I have a LS6 engine, the PCV connects to the valley cover, what are the options with this cover?
George
Good Luck on the install!! Update us on the project!
Question, do you need to re-program??
thanks
Chris
thanks
Chris
Re: Magnuson Intercooler Upgrade Install (1997C5VTBOY)
thanks
Chris
thanks
Chris
George
Hows the upgrade coming, have you got it running again
