Quick ? on rotor swap
In the process of changing out my factory rotors and installing Sportbrakes rotors. When I slide the caliper back over the rotor and retighten the caliper bolts ( on getting those off by the way) the pads rub against the rotors if I spin them.
I know less about brakes then I should, but will the calipers adjust themselves so that the pads aren't touching the rotors once I start her up?
Thanks!
Thanks!
Location: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Originally Posted by ErnieN85
Yes pretty much. did you use some high temp grease on the pins? (sliding bolts)
So I need to re-grease the caliper pins?
Well I guess I'll do that to the fronts when I do them this afternoon, but I already re-lock-tited the rear bolts back in and hell if I'm breaking those loose again . Will my car explode if I don't regrease them this time?
And of course when I pulled the rear wheels last night I found a nail in the tread of one of my tires It's never easy is it? I guess that wouldn't be any fun though.
1 Post
Hey I have had SPort Braes in my garage for 2 months now. Any install Tips?
How did you break the caliper bolts loose? Did you use anything for additional leverage?
Hopefully it will be easy
CI 4-5-6-7 Veteran
Really not that big of a deal and they look fantastic.
Thanks!
Thanks!
To answer another question raised regarding breaking loose the caliper mounting brackets, I used PB Blaster and a breaker bar (about 18 inches long). I was prepared to use heat to break them loose, but they weren't as hard as expected. Keep in mind the rears have the E-brake in them, so a) release the parking/emergency brake when doing the rears and b) realize they don't come off as easy as the fronts.
Enjoy,
DaveR
