I can't believe it!
Location: Spring Hill, Florida Life is all about new beginnings;...TRY ONE!
St. Jude Donor '07-'08
I can't believe it!
Have consistantly been using Chevron and also adding Techron to my tank, and just ONE time this week I put Mobil in because I was too low on gas to find a Chevron station: There it is ........the gas gauge went kaflooey.
I filled with Mobil from almost empty and have only used 1/2 a tank
before the trouble................Wow! I will use Chevron even if I have to walk to the station with a can!
I've been using Mobil since I got the car last year, and I haven't had any issues. Took a little while for the gas gauge to calibrate, but no problems since.
Could be you got some bad stuff...
Sure does seem funny though, that one time I switch, IT happens!......
Received 1,227 Likes
St. Jude Donor '11
FWIW I try to switch my brands of gas a little as all brands use a little different additive mix. When I had my C5, that appeared to help+ the adding of Tecron ( NO Chevron stations in my area)
Originally Posted by 6spdC6
Was that a "high turn over station" It is possible you got bad gas, because it was old or contaimated. I would not blame Mobil in general.
Cruise-In VIII Veteran
St. Jude Donor '07
Why do I feel nervous now about putting gas in my car and I am shipping it from Hawaii and use nothing but the 92 octane that is available on base.
You guys are going to give me a heart attack!
Been rotating my fillups between Costco(VERY, VERY HIGH VOLUME), Shell (VERY HIGH VOLUME) and Chevron (HIGH VOLUME).
No probs. with my '04 so far (5 months).
..rickko..
..rickko..
I just use Super from the closest gas station that I am near and don't have any issues. I can't believe it either that the brand of gas you are usuing can cause a problem with the gauge.
St. Jude Donor '06
I only use Mobil in my car. Started using it just out of convenience but the one time I put some other brand gas, my fuel gauge acted up. Some people swear by Chevron, which I know is good gas, but it's nothing but Mobil for me.
Originally Posted by MyVetteDream
That car of yours sounds like a spoiled brat!
I'm proud of you.
I'm proud of you.
I've used Sam's Club fuel (I wonder who their supplier is?) almost exclusively in the year since I bought the Z06. The only unusual thing noted in the gas gauge operation is that it drops off the full mark prematurely after just a few miles, but then seems to settle down and pace fuel consumption just fine.
Received 19,282 Likes
'20-'21-'22-'23-'24
Hopefully it was just a chance occurrance and you got a bad tank of gas. But, if Chevron never gave you problems, I'd stick with it too.
Knock on wood. I've had 4 different C5s since 2000 and I have never seen the gas gauge problem... And I buy the cheapest gas I can find where ever it is, usually Citgo at 7-Eleven. Maybe North TX gas is cleaner, or something?
