What is Techron gas?
Old 08-04-2005, 12:05 PM
Ken1234
Ken1234's Avatar
Default What is Techron gas?
What is Techron do in gas? I know Chevron has it, but from the posts I see here, it's what we should have in our cars. What benefits are they?
Old 08-04-2005, 12:10 PM
pewterwest99
pewterwest99's Avatar
I know it helps to keep the gas gauge more accurate, but other than that it is supposed to be really good for your car. Hopefully someone will chime in and get a little more technical.
Old 08-04-2005, 12:16 PM
123Gone
123Gone's Avatar
It's a additive to the gasoline, which is one reason why gas with Techron is more expensive. Techron, in a nutshell, keeps your engine clean. Geez, that's sounds like the commercial... From what I understand it's very good stuff.
Old 08-04-2005, 12:30 PM
JR_VETTE
JR_VETTE's Avatar
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Worth reading if you're serious about putting 'good' gas in your car.
http://www.toptiergas.com/
Old 08-04-2005, 02:19 PM
rws.1
rws.1's Avatar
Chevron also has a chemical company. It sells among other things, additive packages for oil and gasoline. Techron is their Brand name for these gas and oil additives.
Old 08-04-2005, 02:23 PM
sandmanusd
sandmanusd's Avatar
I use Chevron with Techron exclusively.. what does it do? Who knows... I'm sure you can find what they say on the box... but what it REALLY does.. ?? DUnno.. would be interested if it does anything...
Old 08-04-2005, 02:27 PM
Dave1998
Dave1998's Avatar
GM also sells a fuel injection cleaner you put in your gas tank. Guess what, same stuff as Techron , different bottle. Its true ! Use it
sandmanusd
sandmanusd's Avatar
here ya go:
http://www.chevron.com/products/prod...derhood.shtml#
Is that a C6 they have there?!
Old 08-04-2005, 05:25 PM
skip faria
skip faria's Avatar
I recently spoke with a gentleman from GM's technical services department regarding fuel pump failures in our company fleet vehicles. He informed me of a number fuel pump failures in CA (not enough for a full blown recall of course!) due to poor quality fuel i.e.,high sulfur content and winter/summer addditives.
When I informed him I recently ordered a new C5 he discussed the importance, especially in CA, to use Cheveron because it contained Techron. Techron apparently is no sales gimmick and it is the same chemical used to remove carbon buildup on heads by all of the Big Three automotive dealerships. He sold me on Chevron and since then I have used nothing else in my cars. In addition, the August 2005 edition of Car and Driver has a great article by Larry Webster titled "Your car is a temple, so put in the good stuff".
Don't shoot me... I'm just the messenger but what I am about to say may tick off a few forum members who swear by aftermarket gasoline additives and octane boosters. Both the GM technical rep. and the above referenced article agree that most additives (especially fuel injection cleaners) may do more harm than good. Conduct your own research, (but do read the August issue of Car and Driver), stay informed, and finally, make your own decision. After all... its your car.. you make the call!
P.S. All 8 Top Tier gasolines mentioned in the article can be found at WWW.toptiregas.com
Old 08-04-2005, 07:04 PM
screw991le
screw991le's Avatar
Location: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
But, the GM cleaner is more expensive and auto zone has it free with MIR right now.
Old 08-15-2005, 11:35 PM
faychinc6
faychinc6's Avatar
About a year back the check engine light came on, on one of our other cars a 98 bonneville. we proceeded to replace the plugs and wires and got the light off for a few weeks. Then put in Techron fuel injector cleaner and got the light off for over a month. Problem was that a bottle of Techron was needed every other week at the end. So we installed new fuel injectors two weeks ago and we'll see how it goes. so far so good. The stuff works as it cured rough idle and miss fireing on acceleration. but only temporarily.
To What is Techron gas?
Quick Reply: What is Techron gas?
