X-pipe, does it change the sound of an after market exhaust ?
For members who added an X-pipe.
What affect did it have on the sound of your after market exhaust ?
Did you notice a difference in the sound ?
x-pipe addition
My vet had corsa exhaust on it when I purchased it and I added the x-pipe. It is a little quieter and more mellow. Don't misunderstand, the corsas are still loud. I didn't get the x-pipe for the sound, but because there is a school of thought that it aids the exhaust flow for a little more hp. Go for it.
Yes, the x-pipe will change the sound of your aftermarket catback or even stock exhaust for that matter. Previously, I had B&B PRT's installed on my '03 Convertible. They were a great improvement over the stock exhaust catback, but there was still a gurgling motor boat sound due to the lack of performance from the stock h-pipe. So, I added an x-pipe, but at the same time, I also added long tube headers and high flow cats. Trust me, at that point, no more gurgling motor boat sound but a much better and deeper and louder exhaust note! I realized that the gurgling was gone due to the x-pipe, and I was going to be disappointed if the x-pipe killed off the popping on deceleration. Quite the opposite in my experience. The popping on deceleration was louder and almost sounded like backfiring at times, which sounded awesome to me. But, then again since I added long tubes and high flow cats, that may have over-ridden the x-pipe's ability to cut out the popping. Not sure on that one.
Now, I've taken the PRT's off and installed B&B Bullets, and the popping on deceleration is deeper and quite loud at times, but it has a good steady note for the most part. It just depends upon how hard of a decelaration I do and if I downshift or just push in the clutch and coast to the stop.
I had the Corsa Pacecar with the stock H pipe and I hated the motor boat sound at idle. I added the MagnaFlow X pipe and the Motor boat sound is gone and the poping is much less. I also noticed it smoothed out the sound alot and it not as loud until you stomp it. I highly recommend the X pipe.
I've had my X in my garage for 2 months now...I need to install ASAP after hearing your posts guys!!!
I have a B&B PRT now, I hate the way it sounds (on car when bought), I'm hoping the x-pipe makes the exaust a little more to my liking
My popping on decel definitely got a lower tone, but I added headers and hi flow cats as well, the resonance at highway speeds got a little less noticeable too....but on WOT, a lot louder, makes my hair stand up sometimes....
s n v f f (04-27-2023)
Received 19,293 Likes
'20-'21-'22-'23-'24
When I put the X-pipe on mine, it made the exhaust note a little deeper, eliminated a lot of resonance and stopped the popping I was getting when I let off the gas. It was well worth the money.
Received 1,675 Likes
It stops the motor boat sound and the popping on decel. It just smooths out the sound.
1 Post
1 Post
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Originally Posted by Jays Z06
Does it remove the cats? Or does it have nothing to do with the cats?
Do it, you'll be glad you did.
Thanks, Grunz
I had my x pipe cut away and welded the holes. It now has true dual exhaust and has the real muscle car sound, before y or x pipes were ever used.
