anyone lowered C5 with this kit
1 Post
Looks like a pretty complete kit and at a good price. Just wondering how low these bushings make the front. Im lowered on stock bolts now and lookin to go another probably 1/2 in.
http://www.zip-products.com/Zip/prod...454EDFD3C0FA3E
quite a link isn't it.
I'm sure the (ZIP) front bushing would be close to the size of your front cut 2/3. Cutting all of your front bushings off in the front is no easier than leaving 1/3. See sig.
Originally Posted by Z28STYLE23
and how much of a chore is cutting front bushings??
1 Post
Originally Posted by double-oh-coupe
The most time consuming part is getting the bolts un-installed (completed unscrewed from the leaf spring) so you can actually cut the bushings. I used a hacksaw and cut both bushings in 5 mins. The rest of the couple of hours of work was dropping the lower A-arm and then reinstalling everything (and a couple of beers). It's an easy job ... just takes a little time and a little elbow grease.
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Originally Posted by mvvette97
I went to the hardware store and got two 7/16 bolts for $5 and used on mine.
Cut the front bushings with a Sawzall without taking anything apart. Get longer rear bolts,grade 8, from a fastener store or hardware if they have 8's. Worked for me.
Fred
Fred
