Good Transmission Shop In Tampa, FL
Old 12-12-2005, 12:49 PM
99bronzecoupe
99bronzecoupe's Avatar
Default Good Transmission Shop In Tampa, FL
Seems as though I need some transmission work soon. Anybody suggest a good trans shop in the Tampa Bay area? Want a good job and not get ripped off. Thanks
Old 12-12-2005, 12:58 PM
Stangkiller
Stangkiller's Avatar
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
What needs to be done? Rodney seems to be the man from whom you should get your tranny's from, then get thim locally installed.
Chris
Old 12-12-2005, 01:01 PM
99bronzecoupe
I got a problem with the 2-3 shift. It's revving up when between the shifts. I don't know if the solenoid is sticking or it needs a rebuild. I have a automatic transmission
To Good Transmission Shop In Tampa, FL
Quick Reply: Good Transmission Shop In Tampa, FL
