Installed my 918's finally.. Glad i did!
i finally got around to do the swap with a really easy tool. just filled the cylinders with air and did one spring at a time. took about 2 hours.
i had a stumble at around 5300 rpms and narrowed it down to valve float. this was from my last dyno.
i was able to feel the power drop when driving. i did a quick pass tonite and the stumble is gone.. i need to get on the dyno again to make sure.
Finished product :
Valve spring tool in action
Finished product :
I just did my springs last week with that same tool. It worked flawlessly and you can't beat it for the $. I bought the air connector also but didn't use it because it was a pain to screw it into some of the sparkplug holes. I just put some rubber tubing inside the hole and rotated the piston to TDC. Worked fine.
Received 19,303 Likes
'20-'21-'22-'23-'24
Nice work.
Nothing like doing it yourself
I just did mine with my borrowed nephews Crane tool.............2 at a time to put on PP Golds, even quicker
Woo-Hoo!
UPDATE: just had my car re-dynoed to day at ICS performance (thanks Brian ) the problem is FIXED!!! all was smooth to 6000rpms.. also picked up a few horses
from 336 RWHP/341 RWTQ to 338 RWHP/346 RWTQ
Received 3,054 Likes
