Drag Radial Advice!!!!!
Old 01-29-2006, 03:18 AM
bigred6906
bigred6906's Avatar
Default Drag Radial Advice!!!!!
I have an 03' Z06 on 19/20 Chrome Z06 wheels. For the track I am about to purchase black motorsports in stock Z06 sizes. I am planning on putting Nitto drag radials in the rear and some brand new inexpensive tires on the front wheels (Falken GRB's). Is this a bad idea? Should I put 555R or 555R2's on the rear wheels. Please help me.
Old 01-29-2006, 12:20 PM
bigred6906
bigred6906's Avatar
ttt
Old 01-29-2006, 08:05 PM
ICaughtVetteFever
ICaughtVetteFever's Avatar
If by track you mean road course, RII. If you mean strip, then Rs
Old 01-30-2006, 02:41 AM
bigred6906
bigred6906's Avatar
these tires would be for the strip
Old 01-30-2006, 03:30 AM
ICaughtVetteFever
Ok, RIIs are out then, sidewall too stiff for good launches
Old 01-30-2006, 08:09 AM
EVIL_C5
Uber Waxer
Support Corvetteforum!
EVIL_C5's Avatar
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
the 295/35/18 bfg drag radials work well.
run em on my car...seen lots of z06's running them too.
Old 01-30-2006, 08:13 AM
JTE
JTE's Avatar
CI 4-7, 9 & 10 Veteran
BFG TA KD drag radials hook very well
Old 01-30-2006, 01:49 PM
ICaughtVetteFever
Wait. I just reread your post, are you getting those Motorsports for the track ONLY? If so I would rethink that, and take a look at the CCW drag pack.
Old 01-30-2006, 11:48 PM
bigred6906
bigred6906's Avatar
ya i got the motorsports.....couldnt beat the deal....$469.00 for black motorsports in stock Z06 sizes.
Old 01-31-2006, 12:12 AM
jdec
jdec's Avatar
Go with BFG's. They are alot stickier than the Nittos.
Old 01-31-2006, 04:09 AM
ICaughtVetteFever
Yes, for the track get the widest drag radial you can from BF goodrich, only reason to use Nitto is for street/strip becasue of treadwear
Old 01-31-2006, 07:33 AM
bglmn
bglmn's Avatar
It's a myth that wider = better. For dry traction, you should
go for a smaller tire (17"), that has more of a sidewall. (M.T.)
There, I said it.
Old 01-31-2006, 08:58 AM
chriscostas
chriscostas's Avatar
i don't think i'd agree with the fact to go with a smaller tire, rather a wider tire with a bit more sidewall to have more of a wrinkle and the width will give you more traction area
Old 01-31-2006, 01:32 PM
waupachino
waupachino's Avatar
Check out the new Mickey Thompson Drag radials, I don't know if they come in the size you need, but if they do they are excellent. They are as soft as a slick. There are a lot of Drag Racers in the street tire DOT approved class running 8 second 1/4 miles using these tires.
Old 01-31-2006, 02:39 PM
vertc51116
vertc51116's Avatar
Location: Mustangs are like Tampons.. Every P*$$* has one!
Where di you find them for that price!? I have been looking all over for them at a price that low!!! PM me plz.
Doug
Old 01-31-2006, 03:45 PM
ICaughtVetteFever
There, I said it.
Yes, that is true, as I said a post before to get 16" wheels in a perfect world, but read carefully above, he already got his wheels. Now he needs to get the widest BFG he can fit with the tallest sidewall.
Oh, and for the record, WIDER IS BETTER. Just don't loose sidewall in the process or you won't gain anything but looks. Tread compound is most important thing concerning dry traction.
Old 01-31-2006, 04:16 PM
YELLOHHH
YELLOHHH's Avatar
315/30/18 BFG drag radials will fit on those wheels, but the sidewall is shorter than the 295/35/18.
To Drag Radial Advice!!!!!
Old 01-31-2006, 04:26 PM
angman5
angman5's Avatar
Get some 17 wheels and put some MT DR on them you will be glad I have made runs with Nittos lowest 60" was 1.8s with the MT 1.6 flat
My silver car only has about 400 rwhp and I could not get hooked up with the Nittos I have seen some A4 cars do well with them.
Good luck
Old 01-31-2006, 08:01 PM
502ci
502ci's Avatar
You said you were about to purchase them...don`t...go with smaller diameter wheels (bigger sidewall, don`t go bigger than one inch tread width than wheel width or they will loose contact patch).
You said these were for the track, so why not a slick.
I have drag radials (BFGoodrich) and mickey thompson slicks for another car and the slicks blow the radials away.
Although it depends on what class your racing in.(street legal)
Old 02-01-2006, 12:48 AM
bigred6906
bigred6906's Avatar
Actually, I already purchased them. The reason I went with the 18 inch wheel in the rear is because I have the large Baer Eradispeed rotors and I need at least an 18 inch wheels to clear them.......
Quick Reply: Drag Radial Advice!!!!!
