VA emissions inspection and OBD-II code question
Old 02-21-2006, 04:03 PM
Crispyc21
Crispyc21's Avatar
Default VA emissions inspection and OBD-II code question
I need an inspection and emissions test done on my 97 soon. Does the OBDII test they run just check for emissions related codes? Because I do get the “Service traction control” light every now and then. I restart the car and it goes away for another month or so but I never clear the code. It’s always an “H” code. Will that make my car fail?
Old 02-21-2006, 06:41 PM
DAVS Y2K
DAVS Y2K's Avatar
Va. doesn't require emissions testing to pass inspection.
Old 02-21-2006, 06:54 PM
WKMCD
WKMCD's Avatar
We certainly do in Northern Va!!! Actually it's every two years fro emmissions while the "safety inspection" is yearly.
Old 02-21-2006, 07:07 PM
mneblett
mneblett's Avatar
Cruise-In VIII Veteran
I just went through an emissions in NoVa. From what I could tell, the OBD scan was solely for emissions-related codes.
The thing that surprised me is that there was no "snif test" as in the past. This was the first OBDII car I've run through VA emissions, and the test consisted solely of the code read and a visual check -- nothing up the car's tailpipe. When I asked why no sniffer, the tech said that the probe's not required on OBDII-equipped vehicles under the VA rules.
jacks996
Jacks996
Support Corvetteforum!
jacks996's Avatar
. I brought my car from out of state and had to get both.
Old 02-21-2006, 07:11 PM
Y2Kvert4me
Y2Kvert4me's Avatar
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Any code that would cause an emissions test failure would illuminate the check engine light.
Old 02-21-2006, 08:25 PM
dpd
dpd's Avatar
you can still fail IF the fault is still there.you could fail the safety part if the person checking the car is a legend in his own mind.heck it before you go and if it's there,just clear it out
Old 02-21-2006, 08:46 PM
CCA Corvette Parts
Premium Supporting Vendor
CCA Corvette Parts's Avatar
St. Jude Donor '07-'08,-'13-'14, '16-'17
If there is a code that pops up on your dash, you will fail...
Peace
Willfulone
Old 02-21-2006, 08:47 PM
dougbfresh
dougbfresh's Avatar
If it's like IL, they check current codes and I/M monitors. Any current emission codes that would trigger a MIL light are a failure and anything newer model year 2000 can only have 1 I/M not pass.
Old 02-22-2006, 10:05 AM
Crispyc21
Crispyc21's Avatar
Thanks for the info.
Old 02-22-2006, 11:08 AM
phils C5 vette
phils C5 vette's Avatar
St. Jude Donor '12-'13-'14
where are you going to have your car inspected with that moster cam ?
To VA emissions inspection and OBD-II code question
Quick Reply: VA emissions inspection and OBD-II code question
