Airbag Light Is On
The light on the console illuminates when the passenger side airbag is turned off. Look in the glove box. There's a keyed switch in there. Insert your key and turn the airbag on.
St. Jude Donor '06-'07
My air bag light was staying on continuously but I was getting codes. I had to replace the SDM. Approx. $450 and I did the labor myself. Make sure you are not getting some codes.
Originally Posted by cody2275
I looked and I don't believe you can turn it on or off in a 98. There is no place to insert a key.
This happened on my wifes Suburban. Turned out our dog got under the car and chewed the wires to the front sensor ( also found out we had a small radiator leak that driped coolant on the sensor ). I spliced the wires back and the light went out. Might want to check if sensor is loose or if a critter has been nibbling.
St. Jude Donor '05-'06-'07-'08-'09-'10
Sorry to hear about this. I just went through a nightmare with mine. The airbag light would come on intermittently. I had it to the dealer (under GMPP thankfully) three times in as many weeks. First the clock spring was replaced, then the divers airbag, then finally when it was hard broke, a control module. Sorry, I don't know off hand, but I do not think it was the airbag module. In all fairness to the dealer it was an intermittent problem and hard to track down.
Best of luck with yours.
