gear ratio info on glove box?
Hard to read your image.........
Do you have an Automatic or Manual transmission? If you have a Manual then the only gears that came from the factory are 3:42.
If you have a Automatic then I belive the G92 is the 3:15 and the GU2 is the 2:73.
Originally Posted by Larry_Yerton
Do you have an Automatic or Manual transmission? If you have a Manual then the only gears that came from the factory are 3:56.
and where is the code on that sticker to show what i have?
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Hard to read your image looks like GU?
No such thing as 3.56 in a C5.
Location: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
of course...if you didn't buy it new, you can always slide under the rear of the car and check out what is stamped on the GETRAG tag on the transaxle (passenger side near the top at the back). My glovebox says I have 2.73's...I actually have 3.42's.
Received 19,293 Likes
'20-'21-'22-'23-'24
You can also look on the rear differential. There should be a tag on it which gives the gear ratio.
Failing all of those - with an A4 put it in 3rd gear, take it up to 75mph. The tach will read 3150 if you have the 3.15, 2730 if you have the 2.73. Works with an MN6 or MN12 in a Z06 too if you shift into 4th gear. It will read 3420 for a 3.42.
The idea is to shift into the gear that is a 1:1 ratio.
The problem with the other techniques is if the rear end was changed - it certainly won't agree with the RPO sticker on the glove box door, and it might not agree with the tag on the outside of the case.
Originally Posted by _supra_
can someone explain how gear ratios work? I know how to shift, I just don't know what the numbers represent
no sticker in glove box.
I typed my vin ....and walla....2.73 gears.... https://www.corvetteforum.com/forums...YY22G6W5109200
I bought my 1998 vette used.
