Will these fit on stock rims?? Please help
Uber Waxer
i had 295/35 drag radials on a set of stock wheels and no issues. the fronts are just 1 size bigger than stock.
check the specs on the tires and their sizing chart, they will tell you what size width rim each tire can be mounted on.
you should be fine with the fronts but i think you'll be pushing it with the rears...
There are a lot of people on here who know a lot more than me about this but hope this helps give you a start
