where do I recharge the AC?
there are 2 ports on the pass. side. one near the radiator fill point and 1 near the battery. you want the low pressure port (the one near the battery). if you car is really low you can put liqiuid in (turn the can upside down) WITH THE ENGINE NOT RUNNING and wait 10min for it to expand before you start it. then only install gas (can right side up).
the ports are covered with black plastic caps and the high pressure is smaller than the low.
More Than Zero
BTW a full recharge takes a little over 2 12oz cans.
More Than Zero
Cruise-In VII Veteran
Received 1,675 Likes
The hose will only fit on the low side and that is the one closest to the firewall.
