1st to 4th Skip Shift Eliminator
Has anyone installed this skip shift eliminator? The GM "great idea" is driving me nuts.....
CAU CAGS 1 to 4 Skip Shift Eliminator for Corvette $19.95
The CAGS 1-to-4 Skip Shift Eliminator eliminates the annoying override 1st-to-4th shift in your 6spd Corvette. Plug protects the open end of the harness from dirt/corrosion. No modifications and easily reversible. Works on all 1997-2006 Corvettes.
Probably most MN6 owners on the Forum !
It prevents the lockout but th elight will still illuminate....
Easy to install, just back onto some ramps and disconnect the old dry pack connector, click the CAGS eliminator into place and click a dummy socket over the old connect to keep it clean...
5 minute job... well worth it
Scientific Negotiator
Received 1,836 Likes
St. Jude Donor '07-'08-'10, '14
What were they thinking...
It was the first mod I did on my '04 Z06
Originally Posted by Mr. Wonderful
It is a fuel consumtion issue, not a performance issue. GM claims it saves fuel with a 1-4 shift...
Your not driving it right!
1 Post
CI 7-8-9 & 12 Veteran
Wounded Warrior Escort '11
Another option is to have it programmed out if and when you re-tune your car. I'm having Dynotech Engineering do this with my C5 while they're retuning after my cam/header system install. This eliminates the light as well.
Paulg680
03 C5 MY Coupe MN6
Paulg680
03 C5 MY Coupe MN6
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
The question is who hasn't installed it. It was the first thing that went in when I got my car. The skip shift drove me nuts when I test drove the C5. I purchased the eliminator before I took delivery. And was installed a day later.
I had the CAGS mod installed, then took it off. Around town the short block V8 has enough torque to easily go from 1st to 4th gear in stop and go traffic. Saves gas, the clutch and my left knee. If I want to run through the gears I can. And if I'm stuck on the freeway at 10mph I go from 1st to 3rd.
When gas gets to be $4.00/gal it will become more important.
Location: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
Let me think if it was not for GM's Great idea as you call it, it would cost you a few thousand dollars in Gas Guzzler taxes if you bought the car new. The corvette is one of the only few performance cars that does not pay the tax.
So let me think again $19.95 or $2000 plus
You make the choice
You make the choice
You make the choice
To tell you the truth - I don't have a CAGS elinimator and CAGS doesn't bother me at all. I think in the almost three years I've owned the car, I've seen it come up only a handful of times. Just because the 1-4 Shift light comes on - that does not mean you have to shift then. Run it up higher in the rpm range and shift when you want....$20 saved and a heckuva lot more fun. Drive it like a perfomance car, not a Cavalier.
I don't think I've seen it more than 20 times myself, doesn't bother me one bit, if it shifts me into 4 it's only because i'm barely pushing it to begin with so I don't really mind the upshift, the V8 pulls along just the same. I've found it's intelligent enough to have never once interupted when I didn't want it to.
