[pics]HUD install, one of the best mods for <$400
Cruise-In VII Veteran
as many of you have noticed Pacethis has recently become a supporting vendor selling HUD kits, these kits take all the hassle from tracking down parts, specifically the '11-pin hud harness' (unavailable from GM)
nyhollywood recently made the trip from Long Island to CT for the install(not a bad drive when you have a Vette Doctors Rx450 equipped Nassua Blue FRC)
parts inlcuded in kit:
HUD projector w/ hardware and double sided tape for mounting
HUD switch(replaces dimmer on stock gage surround)
HUD bezel(trim to fit into dash pad)
HUD harness(uses one end of the original dimmer harness)
very detailed instructions
most '99 and newer c5's are equipped w/ the HUD cluster
dash pad removed and HUD installed(about an hour)
HUD projector, the harness is part of the projector, this plugs into the top of the cluster
here's the difficult part of the install, trimming the dash pad, i used a few new razor blades(lenox makes a nice utility knife), first 'scribe' the lines, then make a few passes to cut the hard plastic(1.5 hours)
total time to install? 3 hours, the dash pad requires patience when trimming, no epoxy or glue needed, when done correctly, the 2 tabs grab the underside of aft bezel and 4 retainers hold the 4 post of the bezel
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Originally Posted by red97vette
awsome, thanks for the great tips!
dan
dan
Steve, great job!
Not sure I'd want to take my dash apart to that degree. Glad that HUD came on my car. Guess I will be pretty much gutting the interior when I do my stereo install though.
CI 7-8 Veteran
A word to the wise, do not use a battery powered Dremel to do this, use a corded one. There just isn't enough oomph in the battery jobbie.
I'd think anyone w/o HUD would want to do this. Good info.
