List of owners with EBCM ISSUE ?? ??
#641
It is an aftermarket tool for fixing the column lock problems that many C5 models have. Mostly Manual transmission cars.
http://www.complianceparts.com/lmc5ataglance.html
LMC5 installs in minutes, in the passenger side foot well, would be hooked up to your BCM
#642
Had one replaced under warranty
Second one failed a few months ago (TCS NO Comm - unrepairable) Replaced with used one off Ebay for $340. It included pump module which I sold for $100. So net cost was $240.
Both failures occurred after recharging battery. Going forward, will disconnect battery when recharging.
#643
#645
Wow this is some really good information! I really appreciate it! I did pull my codes and of course had the C1255 and C1243.. I do have a new AC Delco battery installed, hopefully troubleshooting will begin this weekend and I'll report back.
#646
Did you click on this link and read it...http://www.complianceparts.com/lmc5ataglance.html
I think it's all covered...but if you have questions call compliance they are super nice and helpful!
#647
#648
Yeah you need to call compliance and talk to Richard...disconnect the relay and do the brown wire fix ... he'll talk you thru it. Good luck
#650
Purchased the car in February 2013 with a pre-existing ECBM problem. Procrastinated for about 6 months. Took it off sent it to Wisconsin. $50 and 5 days later it was returned to me with full warranty. spent another 45 minutes putting it back on. Not as single EBCM problem since.
Also, Used my flexible shaft screwdriver handle and adaptor for the bit, then using masking tape, taped the head of the screws to the torque bit to get them started. Easy. Peasy.
#651
#653
that was the case for a long time but I know of a few people that have had there 2000 - done with no problems - when I purchased my 2000 FRC I was told the same thing so I started investigating it and talked to the people at airbags - I also found some who had 2000 that had used there product and it worked.
#654
#655
Subject: Do you repair the EBCM on a 2000 Corvette
Fri 3/6/2015 1:42 PM
Hello,
Yes we do service this EBCM. The price for the service is $89+$18 for return shipping. Once we receive the module we will have it serviced and shipped back out within 24 hours. Shipping typically takes 3-5 days.
Please remember that you only need to send the electrical portion; not the pump. Sending the pump may damage the module and will add to your shipping costs.
Send items to:
My Auto Solutions
2005 Boggs Rd
Duluth, GA 30096
Include following:
1. Your Name, Phone
2. Return Address
3. PayPal receipt, check/money order payable to My Auto Solutions
Please let us know if you have any other questions.
Thank you,
MyAirbags Team
678.778.8890
2005 Boggs Road
Duluth, GA 30096
Hello,
Send items to:
My Auto Solutions
2005 Boggs Rd
Duluth, GA 30096
Include following:
1. Your Name, Phone
2. Return Address
Thank you,
MyAirbags Team
678.778.8890
2005 Boggs Road
Duluth, GA 30096
#656
Hello,
Send items to:
My Auto Solutions
2005 Boggs Rd
Duluth, GA 30096
Include following:
1. Your Name, Phone
2. Return Address
Thank you,
MyAirbags Team
678.778.8890
2005 Boggs Road
Duluth, GA 30096
Hello,
Send items to:
My Auto Solutions
2005 Boggs Rd
Duluth, GA 30096
Include following:
1. Your Name, Phone
2. Return Address
Thank you,
MyAirbags Team
678.778.8890
2005 Boggs Road
Duluth, GA 30096
#657
I have a 2001 Z06 with the dreaded abs no tc problem. Sent it in to my airbags for the fix. Reinstalled and no luck - asked for a refund. Will let you know if they process the request. Bought a brand new unit and plan to install that - should do the trick I hope.
Benspeeder
Benspeeder
#659
Replaced mine with one from GM Parts for $450 and about 2 hours labor. No more ABS or TC codes. I sent my old one to a repair center and they told me it wasn't repairable. 2004 LeMans manual trany.
#660
1999/Convert - 56,000 miles
Bought in late 2013 with 52,000 miles on it started throwing the C1283 code within 30 days of purchase. Dealer is sending out a service tech to pull the abs module and get it fixed as the car is in storage right now. Sure hopes this works, dealer is still covering under original 30 day warranty.
