List of owners with EBCM ISSUE ?? ??
Here are the current members with EBCM issues and their status (please update if incorrect)
Repaired under Goodwill Policy
dmcantrell - 2003 vert - covered under goodwill policy
rikhek - 2004 Z06 - covered under goodwill policy
nuch - 2003 coupe - covered under goodwill policy in Canada
Bill Curlee - 02 Z06 - 02 Z06. replaced EBTCM, RF wheel harness connector. $1700. + $1600 towards the purchase of a new GM vehicle
03QuicksilverZ06 - replaced in Halifax (would not pay for $110 labour charges)
Rob'sC5 - 2003 - replaced under goodwill policy
frosvette - 2002 Z06 out of warranty. EBCM went bad. Parts manager and service manager at Woodard Chev helped out getting him a reasonable price for repair.
CarolinaC5 - 2001 50,100miles $525 (labor) GM covering part - said it was listed at $2600
Purchased Part
jrc27 - 1998 - purchased part #9367071 EBCM for $277
Bret01Z06 - 2001 - 52k - $200 off a repo
brokebyducati - 2000 - EBCM AND BPMV paid out of own pocket $$$$
Lancer033 - 2002 - purchased new EBCM for $650
CHRP 1 - 2001 Z06 - 1/2 covered but cost $1200 of a total $2,984.00 repair EBCM and also brake pressure modulator valve
Filmelf - 2004 - replaced at dealership at own expense
Joey Walnuts - 2000 fixed @ dealership for ~$1100 + 2002 currently not fixed.
Flash of Red - 2003 ZO6 - parts and labor was $900.00 at dealership
9T3JIM- 1999 FRC - Purchased EBCM from Fred Beans and installed himself.
JimBacus - 2002 Z06 - Purchased and installed himself
Replaced Under Warranty
CalHusker - 2001 - Replaced under GMPP warranty
roscoe118 - 2002 - Replaced under warranty
jedicowboy - 1998 - Replaced under 3rd party warranty 75K
Glennm27 - 2002 - replaced under GMPP
KonaVette-1998-EBCM from Fichtner Chevrolet $340.49 DIDN'T SOLVE THE PROBLEM.... IT WAS THE GROUND WIRES.
3RD-INF - 2002 - replaced 8/05, 28,000 miles
BQuickSilver - belt chewed through wiring, shorted out EBCM - replaced under GMPP
DeeGee - 2002 A4 Convertible - Replaced under GMPP extended warranty.
HerringChoker - 2000 Coupe - Replaced by 3rd party warranty: efgcompanies.com Cost: $50 deductable. EBCM- $524, BMPV-$1862, LBR. $268. Total out the door,$2776.00
74-Roadster - 2001 Convertible - Replaced via GMPP warranty, 9-14-06
Unsure of status of repair
eaZy06 -- 2001 - 20,800 miles.
Marine - 03 Z06 - ??
C5_ChemE -
ThePatriot - 2001
chiefDave - 2001 Z06
TexasAg28 - 2001 - ??
C5_pewter_vette - ??
c502 - 2002 - ??
camaro_zach - ??
4DRUSH - 1997
nprsuit - 00 with 26K -??
dh305 - 00 with 28k -??
barrynk - 2001 convertible, 29,000 miles
jarscoupe - 1998 - warning coming on at 70mph
Sandy_S - 2003 Z06 - taking it in for service
Purchased Part
C5_ChemE -
ThePatriot - 2001
c502 - 2002 - ??
camaro_zach - ??
4DRUSH - 1997
Originally Posted by 01QuickSilver
OK, I have no pride - I'll show my ignorance.......
What the hell is this thread about ??????
Purchased Part
add me in, jrc27 where did you get one for $277? Was it used?
UPDATE: Installed ECBM today and it fixed the problem. Didn't even have to clear the codes, they were just gone. I expected the history code to still be there, but oh well. - at least it works now and I'm only out $693 ($650+shipping)
Installing the new one wasn't bad, the only issue I had was seperating the ECBM and PBMV. Service manual says to gently pull them apart, but I had to use a screw driver to pry them apart. Other than that, just unhook the wires, take the 6 T20 screws out, pull them apart, then put it all back together.
If you don't have a warrenty, do it yourself
If you've done the trouble shooting and nothing else works (clean all the electrical connections) to see if that works, then buy the part and install it yourself and save a whole bunch of money.
Ebcm Dtc 1214
Driving with no ABS. DTC 1214 on all of the time. Time to replace the EBCM? After reading all of the post's, this is a very difficult problem to deal with. Spending this amount of money for a part, that may or may not correct the problem is difficult. Also, how important is the ABS?
ebcm module
I have a 2001 ZO6 with 15,000 miles,i have same problem abs and traction control lights on all the time on dash.Took to dealer,said EBCM and also brake pressure modulator valve BAD.Total cost $2,984.00 to fix.GM said they would pay for half under good will policy.Sounds like a lot of corvette owners have this problem.personally,i think GM should cover the total cost to repair.MY $.02 cents.
Purchased Part
Rob'sC5 - 2003
ThePatriot - 2001
c502 - 2002 - ??
camaro_zach - ??
Please copy and paste, and update with your info...
thanks
Purchased Part
Rob'sC5 - 2003
ThePatriot - 2001
c502 - 2002 - ??
camaro_zach - ??
thanks
ebcm
Talked to service manager,will cost me $1,200.00 out of my pocket.I am going to have it fixed,yet i still believe GM should cover the total cost.GM will pay half.Total bill $2,400.00.
