WUB,GreenMachine Traction Control repair, shift light, Pics Vids etc.
2017 C6 of the Year Finalist
Cruise-In VI Veteran
So I wanted to go out and see Fast and the Furious 3 tonight......but there were no takers. So I decided to break into my Vette To Do list.
Steve (FixedRoof) came over to give me a hand......thanks again man.
1. C1288 Code
2. LED DIC buttons and dimmer switch
3. Install Shift LED into Cluster
4. Track down which fuse controls the Fog Lamp/Hatch/Fuel Door Switch.......Fuse #32 passenger comp.
We got all this done!!!! Im very happy. The GreenMachine is perfect again.
C1288 code: See post in C5 Tech...
http://forums.corvetteforum.com/show...post1555727355
So since the steering column was out I did my DIC buttons and dimmer switch in green LEDs. To match everything else.
Sorry the pic is so crappy, but that's not important.
Awhile back Steve (FixedRoof) had posted pictures of the shift light that we had installed in his FRC.
So since everything was apart we did it up on the GreenMachine. It is physically integrated into the gauge cluster. Electrically via PCM programming 5800 rpm (Redline 6400) and the use of a microrelay. The tune uses the Skip shift 1-4 circuit to provide the logic for the shift light. So that bulb is removed and the circuit forwarded (wired) to the shift LED (5000mcd Green T1 LED).
Cluster Out
Continued...........
1. C1288 Code
Cluster Out
So at 5800 RPM this LED goes crazy bright. Fills the whole cluster with a massive green glow. I LOVE IT.
Here is a very short video showing it in action. CLOSED COURSE.
Shift LED Video Link
Later,
Max
Later,
Max
WUB max the the LED machine wanted to see triple the gayness or some movie we opted out of. Car is sick as always. Just need to get the bald Drag Radials off of it and mount the 335's.
Chris
Chris
Yeah man.. Glad everything is fixed now. It was fun an looks awesome. It is really bright! We got those matching shift lights now.. hehe...
later
Steve
later
Steve
WUB! you guys are crazy! LED is awesome man! i might have to bug you to do mine.... blue of course.... but 5800rpm?? how about 7000rpm
glad to see everything is back to normal. always a good feeling. now you are free for sunday so we can go see the fast and the grimey!
OK....I need to do this. Do you have more details like part numbers and a schematic available?
Scientific Negotiator
Received 1,836 Likes
St. Jude Donor '07-'08-'10, '14
NICE MAN!!!
I'm working on it for you guys. I'll try and have it up today.
Thanks for all the comments. What's next for the GreenMachine........?
Later,
Max
Later,
Max
Later,
Max
Sweet
Details
OK
The PCM will have to be tuned for the '1-4 skip shift' light to activate at your desired shift point which should be slightly lower than your redline.
Here is how the hardware is set up.
Rear of cluster
Relay Circuit
Feel free to PM myself or Steve (FixedRoof) for more details.
Later,
Max
Rear of cluster
Relay Circuit
Later,
Max
