can somebody tell by a VIN number if a car is an auto or manual transmission?
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
Sure you can find out with the VIN, many here can access that database info.... one will chime in or PM you soon maybe
A4 trans. here you go!!
GM Vehicle Inquiry System
Vehicle Build
Home - Summary - Claim History - Vehicle Build - Vehicle Component - Delivery Information - Dealer Information - Service Contract - Warranty Block - Branded Title
Help
VIN 1G1YY22G145112874
VEHICLE BUILD
Merchandising Model : 1YY07 -2004 CORVETTE COUPE
Gross Vehicle Weight Rating : 1678 kg (3700 lb) Order Number : GQGG19
Build Date : 10/31/2003 Build Plant : 145Y
OPTION CODES
AAB - MEMORY PACKAGE
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT
B84 - BODY SIDE MOLDINGS
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
C2L - ROOF PACKAGE
DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
DD8 - OSRV
DL5 - ROADSIDE SERVICE INFORMATION DECAL
FE1 - SUSPENSION SYSTEM-SOFT RIDE
FE9 - 50-STATE EMISSIONS
GU2 - REAR AXLE 2.73 RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR
LS1 - 5.7L LITER SFI V8 - 350HP
MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
NK4 - LEATHER WRAPPED STEERING WHEEL
NT9 - FED EMIS SYS, TIER 2 PHASE-OUT
N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
QF5 - HIGH POLISHED ALUMINUM WHEELS SLM - STOCK ORDERS
T82 - TWILIGHT SENTINEL
UN0 - AM/FM STEREO W/CD PLAYER
UV6 - HEAD UP DISPLAY
UV7 - WINDSHIELD ANTENNA
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U52 - ELECTRONIC INSTRUMENTATION
VDC - VEHICLE INFORMATION CD
VM3 - CONSUMER INFORMATION LABEL
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGG - FRONT TIRE-P245/45ZR17 BW SBR
YGH - REAR TIRE-P275/40ZR18 BW SBR
1SB - PREFERRED EQUIPMENT GROUP * MEMORY PACKAGE * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR * HEAD UP DISPLAY * STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
1SZ - PREFERRED EQUIPMENT SAVINGS
67I - LIGHT OAK INTERIOR TRIM
673 - LT OAK SEATING TRIM
79U - PREMIUM COLOR MILLENIUM YELLOW
© 1998-2005 General Motors Corporation. All Rights Reserved.
Vehicle Build
Help
VEHICLE BUILD
OPTION CODES
C2L - ROOF PACKAGE
DD8 - OSRV
Thank you! My dad is looking for an A4 so this may be his new car!
Vehicle Build
Help
VEHICLE BUILD
OPTION CODES
C2L - ROOF PACKAGE
DD8 - OSRV
Vehicle Build
Help
VEHICLE BUILD
OPTION CODES
C2L - ROOF PACKAGE
DD8 - OSRV
