STEP 2 of my LED changeover
***EDIT***
i am not responsible for you ordering the wrong bulbs - so don't get mad at me if yours aren't as easy as mine were - i have a 1999 FRC - so those with newer cars - DISASSEMBLE your assemblies prior to ordering to avoid confusion and possibly ordering the wrong parts.
some may recall my first post of STEP 1 - http://forums.corvetteforum.com/show....php?t=1426245
thanks to a little help from several forum members - spdkilz, and SpeedyZ - i have changed the LED bulbs in the door "power" switches, the trunk release and the Active Handling button
contrary to popular belief - the NEO WEDGE bulbs that are half way down THIS page are DIRECT FIT in my '99 - no grinding, no soldering, no resistors, no NOTHING!
i am 2 short - as i need 2 for the drivers door, because i was informed that the active handling and trunk release use the same bulb, so i opted to test those first!
then i'm moving on to the DIC - my '99 only has a right side DIC which i understand are the same bulbs as the power switches, which i also understand is the same bulb as the trunk release, which i also understand is the same bulb as the active handling panel -
FYI - for those that are planning on this - i have found out that there is a POSITIVE and a NEGATIVE to these bulbs - not sure which terminal on each bulb input is + or - but if you reverse them, no harm, i actually found out they were + and - by using a 12v power plug on a spare PC!
a slightly helpful tip i used was to use a SILVER sharpie to mark which side was + that way if they didn't work when put in the car, i would have a point of reference as to which way the bulb was originally inserted - then do the opposite!
no pictures yet - as i did it on my lunch 1/2 hour at work!
parst list required for this mod -
NEOWEDGE bulbs listed HERE about hals way doen the page (see my picture below)
11-12 total - breakdown of quantities - 4 for the drivers power, 2 for the passenger power, 1 for the trunk release, 1-2 for the active handling/traction control and 3 for the DIC.
194 bulbs HERE i chose the matrix bulbs
3 required (1 for under dash on drivers side, 1 for under passenger side, and 1 for rear "trunk" area on passenger side)
"festoon" bulbs for the rear view mirror (i would speculate that it is the same part in '97, '98, 99 - but can only guarantee it IS in the '99 - and i have no idea about newer - see spdkilz (with the .com) for more information on how HIS mirror already had LEDs inside!
festoon bulbs are HERE
and my preliminary tests show that i will be getting the SUPER STAR
- as those suckers are almost BLINDINGLY BRIGHT with a 9 volt abttery hookup - so facing down with the correct 12v tucked in the mirros shoule emit a NICE BLUE GLOW
picture of the festoon bulb in question is
this concludes what i have done so far, and will continue to update this post when i find other LEDs to change out - as now i want to see if i can change the light behind the "dimmer" for the gauges
10mm wide x 44mm overall length
Anxious to see pics.
Originally Posted by eec8059
I've been wanting to do this for awhile as well. What is the part # of the Neo Wedge LEDs for the door? Maybe that'll be a start.
it's the bulb that is $2.99 ea.
picture here -
St. Jude Donor '06
Originally Posted by Stealthy4
When you say DIRECT FIT...do you have any pictures of the DIRECT FIT? Thats unbelievable! I want to see how these thing plug in! I wanted to do the LED mods but the resistor work was a bit much. Show us PICS! Thanks!
and when i say direct fit, i mean, UNSCREW the old buld, SCREW IN the new bulb and voila!
i'm gonna wait until it gets dark tonight then snap you guys a few pics - look for them maybe later tonight or tomorrow morning
just to warn you, my digital camera is kind of a piece of crap so here goes
the one with the power "panel" for the door was shakey because i couldn't hold still, but you should get the idea
FYI - the one on the LEFT is the LED - the one in the middle - is the same height at the LED and a tad taller than the one on the right - but as i posted before i i had NO FITMENT ISSUES WHATSOEVER!
heck, while i was at it, i replaced my under dash lights with 194 LED bulbs as well as my drivers side "trunk" (i have an FRC) light with a blue 194 LED as well - FYI also, i have a 1999 (FRC) so for all you guys with newer cars - please use caution and REMOVE YOUR BULBS first before you order -
if you look at SPDKILZ website (just add .com) he has a couple good writeups on how to remove the stuff to replace the bulbs - and HIS mirrors already have LEDs in them - my mirrors have "festoon" bulbs in them, so when i order, it should be a simple replacement - last thing i will be doing is the DIC - as like i mentioned, SPEEDY Z told me they are the same as the ones in the traction control / trunk release
good luck, and post up when you guys finish!
Thats pretty cool that you can now buy a direct fit replacement for the folks who want to do the LED mod without the soldering effort. I would be wary of these bulbs fitting in the left side of the DIC though. Those bulbs are quite a bit smaller. Looks awsome though.
BrianWe - have you done the LED mods? if so, how many are on the right
side DIC?
thanks Brian, i guess i need to order 5 more (maybe a 6th) as i need 2 for the passenger door power, 3 then for the DIC and i'm gonna try one more for the active handling - as it's pretty dim, i may have it either in the wrong slot or perhaps it needs both filled.
OP edited with breakdown of parts list needed FOR MY 1999 ONLY - your parts list may be different
Togo,
Put 2 bulbs in the active handling. Unfortunately, it will still be dim, but brighter than with one.
Togo,
The right side of the DIC takes 3 bulbs.
-Brian
-Brian
Originally Posted by keliente
That is sweet. Does the cluster have to come out to remove that DIC panel?
i'm about 95% sure that NO, it does not - but spdkilz.com has a great how to for disassembly
