rear license plate frame C5
Just received my new plate for my C5, Looks like I need to remove the frame (rear) to mount it. How is this done - afraid to pry out since its plastic and might break. any help would be appreciated Thanks
If you look carefully at the factory plate surround you'll see 4 tabs that need to be pushed in slightly with a screw driver. It will then pop off.
