need driveway approach redone...
Old 08-07-2006, 03:28 PM
130NA5
130NA5's Avatar
Default need driveway approach redone...
I bought a 01 coupe about 4 months ago and I barely get to drive it because my driveway approach is to steep. I have been putting down a ramp to get in and out, but I am tired of doing that. Does anyone know someone that could pour a new driveway approach? I have had a few companies come out and look at it and they always say it is too small of a job for them. Any help would be greatly appreciated.
Old 08-07-2006, 03:30 PM
rws.1
rws.1's Avatar
I saw one that was done with the steel . They welded up a wedge the eidth of the driveway , drilled about 6 holes thru it and used large spikes to hold it in place.
Old 08-07-2006, 03:34 PM
130NA5
130NA5's Avatar
I actually want someone to come out and jackhammer the concrete out and pour a new approach. The city said they would do it next year when it is in their budget, but I do not want to wait that long.
Old 08-07-2006, 04:07 PM
blacksedan87
Support Corvetteforum!
blacksedan87's Avatar
Location: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Try backing in......
Old 08-07-2006, 04:11 PM
VetterGetIt
VetterGetIt's Avatar
Old 08-07-2006, 04:20 PM
jrose7004
jrose7004's Avatar
Received 1,675 Likes on 1,298 Posts
Look in the sevice directory of your local paper. There are always lots of small contractors around for jobs like that!
Old 08-07-2006, 05:12 PM
0Double D Mods
Former Vendor
Double D Mods's Avatar
St. Jude Donor '12-'13
I had the same problem, but with the frame rail savers to help the car up the incline my problems went away. Believe it or not, it seems easier to pull in and out of the driveway now with it lowered on stock bolts than before. As far as backing in goes it doesnt work as good for me, but give it a try.
Old 08-07-2006, 09:21 PM
Humanoid 2.0
Humanoid 2.0's Avatar
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Go by your local home center and pick up a few illegals, they love to do concrete work.
Old 08-07-2006, 09:33 PM
99C5Vert
99C5Vert's Avatar
St. Jude Donor '03-'11
backing in is worse... i have the same problem. I have been coming in at an angle, but even then, I'm totally abusing the black rubber strip in the front.
I'll be digging up the front 3rd of the driveway and resloping it in the fall.
Old 08-07-2006, 09:53 PM
...Mark...
...Mark...'s Avatar
Also angle it if you can... My vette scrapped stock ride height. I lowered it a little over an inch and can back in (slowly) with no problems.
Old 08-07-2006, 10:01 PM
undertaker
undertaker's Avatar
Location: ECS : WTF did you break now and HTF did you break it this time
just scrape it......tahts what I do.....blends in well with the track rash.
also if you dump the clutch upon entering the driveway it should lift the nose adequately to clear it...
Old 08-07-2006, 10:16 PM
wamara
wamara's Avatar
Cruise-In II Veteran
You can buy an awful lot of those easily replaceable air dam strips for the cost of the new concrete. Plus put some frame savers on and you'll be good to go !!
Old 08-08-2006, 03:06 AM
RebelVette
RebelVette's Avatar
If the city will do this for you, then I would really wait. Concrete work can get very expensive (especially if not done right the first time). I have ramps that work for me and I've been using them for 2 years now. Guess you just get used to them.
Old 08-08-2006, 03:23 AM
TA8088
TA8088's Avatar
Old 08-08-2006, 03:30 AM
GrayC5
GrayC5's Avatar
...or post over in the Southwest regional section of the Forum. Some of the folks in that section may be more likely able to provide you with some recommendations for contractors in your area.
Good luck.
Old 08-08-2006, 07:29 AM
99C5Vert
99C5Vert's Avatar
our is bad enough that when we put the trailer hitch mounted bike rack on the van, that drags too... plus, the driveway is pretty cracked, so it's only a few hundred $$ to do it right.
Old 08-08-2006, 12:12 PM
BATM4N
BATM4N's Avatar
Go to this site http://eliteengineeringusa.com They have C5 Frame Guards specifically made for steep inclines. It will save you a lot of trouble until they fix it next year.
To need driveway approach redone...
Old 08-08-2006, 12:20 PM
130NA5
130NA5's Avatar
Thanks everyone for all the ideas. I have tried them all and the only thing I can do is put ramps down which is a big pain in the butt. I bought frame savers and that wouldn't work and I have tried backing in. One of the estimates I had done was for $2000...I agreed to that but then we had those protests down here in Texas and he couldn't get anyone to work fearing deportation. Some crazy crap! Anyways thanks for the feedback and i look forward to any more ideas anyone has.
Old 08-08-2006, 12:24 PM
Big Jay E
Big Jay E's Avatar
My wife surprised me by having our driveway ripped out and redone so I could get the Vette in. I never asked what it cost.
Jay
Old 08-08-2006, 12:27 PM
CVG323
CVG323's Avatar
... LOL ...
i know alot of day laborers and this is funny. believe it or not, they do pretty good jobs.
im a fellow illegal here, and i take no offense to this..lol
Quick Reply: need driveway approach redone...
