Need help on transmission fluid change
Time to change the A4 transmission fluid. (25,000 on 1 car and 40,000 on the other. Checked with a dealer and they don't use synthetics. They have two options; a flush which changes all the fluid but not the filter, or a filter change which only changes about half of the fluid.
What's everyone been doing? Do I need a filter change or just the fluid?
Is this a job I can do in my garage?
What fluid is best?
Also, should I change the fluid on the MN-6? At what mileage? What fluid?
What fluid is best?
Owner's manual says every 100,000 miles (yes, 100,000 miles, no typo)on the A4 UNLESS you drive it in mountainous terrain (not in Indiana I think) in which case you should change it every 50,000.
I'm researching types and all your other questions as well right now as I live in the mountains and am over 50,000! Hopefully we get some good input!
Ok, I take the easy way out. Every 35,000 miles I let the dealer and sponsor of our Corvette Club change the tranny oil. About $130 at the dealer every other year or so. Jim
