multi function switch
I have no idea what to what switch you are referring.....what does it do?
Also, you may want to update your profile with the model year, type (coupe, vert, FRC/Z06), mods and any other pertinent info on your car. This could greatly benefit others here when attempting to answer your questions and assist you.
Good luck!
Good luck!
Received 19,358 Likes
'20-'21-'22-'23-'24
Could you possibly be talking about the turn signal/cruise control stalk? Otherwise, not sure exactly which switch you mean.
Remote Function Actuator - a.k.a. key fob?
That is what is normally called the multifunction switch. So, Carlos, if that's what you need then the part# is 26075870, at least for the earlier years. Not sure if it's the same for '00 and later, no clue to what year your car is. Easy change out, just make sure to have a torx bit as a driver will not get one of the screws out
Multifunction Switch C5
Thanks everyone for the heads up info!!!!!
RandW,Thank U especially for the parts #.
That was it!!
I have a 1998 c5 Hatchback!
The dashlights and tail-lights quit working,but break lights work!
Thanks Everyone once again
And may GOD bless all of you
Carlos
That was it!!
Carlos
