Help with CD changer.....
Up until today my 12 disc changer (stock) work perfectly. All of a sudden it doesn't! I get an "Err" message. I open up the changer but the magazine does not eject like it's supposed to. Any ideas?
Thanks guys!
Thanks guys!
Mine did that a while ago and I ended up getting another one replaced via my extended warranty. However now I upgraded to a DVD player and don't need my unit anymore. If u find you need another one, let me know and I'll sell you mine.
St. Jude Donor '06
I haven't had your problem, but mine won't play discs I burn myself. That's OK though, I use an Ipod now - 250 CD's and I'll gain some trunk space when I take the changer out.
Originally Posted by Roostertail
That's a nice offer
St. Jude Donor '05-'06-'07-'08-'09-'10
Wow - great offer right there.
If the carrier won't eject, I believe there is a small button that can be pressed, perhaps with a paperclip end, to manually eject it???
The guys in the audio section will know for certain.
Best of luck.
Thanks guys!
Thanks guys!
Originally Posted by hdff
how does the ipod hook up to the stock radio?
http://forums.corvetteforum.com/show....php?t=1392384
Cheers,
Rog
Try disconnecting the changer's cable (underneath the changer), and leaving it disconnected for at least 10 minutes. Then plug it back it. Let it sort through the discs before trying to remove the cartridge.
If that doesn't work, then it "may" be that a disc is jammed between the player mechanism and the cartridge (happened to me on my first changer -- I'm on my third one now, plus I've installed the iPod2car by Peripheral).
Also, don't forget that the CDs actually fit into the individual trays face (label side) down. I couldn't figure-out why my original cartridge would play, yet one of my spares kept getting an error message and/or just wouldn't do anything except display a CD on the stereo's display screen. I compared both cartridges, only to discover that I had placed the CDs label-side up instead of label-side down...which is the correct way.
BTW, my burned copies of my originals play fine now.
