Help - what wire runs to fuse 22?
I'm trying to connect the ACC wire on my head unit to fuse 22 in the passenger side fuse box. Does anyone know which wire runs to fuse 22? How do you remove the fuse box in order to see the wires? Thanks.
Below is the schematic for your '04 Z. Fuse 22 appears in the center of the drawing. Also, you can see a pic of my IP fuse block in the passenger footwell where I used a Minifuse to add accessories to the block at the link below.
http://www.redshift.homestead.com/minifuse.html
Here's the layout of the fuse block.
http://www.redshift.homestead.com/files/c5-fuse.pdf
