Need Brighter Backup Light Bulbs
Does anyone have some information of brighter than stock backup light bulbs other than going LED. Any info will be greatly appreciated
Scotty
Scotty
Night Owl for life
Received 3,241 Likes
LED's are not brighter than stock.
stock on left, LED on right:
These diamond-cut backup housings may be a better choice for more brightness.
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
I have four of the diamond cut backup lights in-stock and ready to ship....make a huge difference.
http://southerncarparts.com/9704-bac...ate-p-135.html
Thanks,
Jim
Thanks,
Jim
Thanks,
Jim
Thanks,
Jim
Scotty
Night Owl for life
what do you mean by the factory lense?
The Adjure unit appears to come with a clear lens covering the diamond cut reflectors, while the factory backup light assembly comes with a pattern design on the lens. I have never removed factory unit nor have I seen the Adjure unit it person, so I do not know if the lens over the bulbs is removeable or if the bulbs are mounted through the backside of the assembly. Thanks
Scotty
Scotty
Night Owl for life
oh the bulbs poke in through the back of the lenses. you have to take off your license plate surround to access 4 torx screws and then you pull it all out together.
the stock unit is opaque, so you cannot see the bulbs, whereas the adjure unit has a clear cover and the bulbs are plainly visible.
My 99 coupe is black and I want the rear fascia to have an understated look without the bling of the "diamond cut". That is why I was looking for some brighter bulbs. There is a supporting vendor selling "black out" lighting accessories with the Adjure backups being one of the items, I just don't remember who it was. In a best case scenario, I would have the Adjure backups with blackout & hopefully the diamond cut pattern would reflect more light through the Adjure blackouts than the factory backups produce. If that is not the case I may purchase the Adjures without blackout because I NEED more light to see when I am backing up, and who knows, I may love the bling . Thanks for Helping me out
Scotty
Scotty
I don't think that the "bling" is so noticeable, it has a clean look. I'll try and get a close up in daylight and post it later. I love mine and even with stock bulbs it is brighter, backing out of my garage I notice it more so.
Scotty
Scotty
Edit - Link to seller: http://forums.corvetteforum.com/show....php?t=1547051
ulb, 50 Watt Halogen, 19 16
63-1996
Ordered these from Ecklers and they're supposed to be brighter even with stock lenses
Night Owl for life
Scotty
Scotty
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Replace the complete unit with the Azure one - it will make a LOT of difference in light at night when backing up
