Real stupid question about jacking pucks
Old 01-26-2007, 11:10 AM
Ruz
Ruz's Avatar
Default Real stupid question about jacking pucks
Please excuse my ignorance on this one...
I am assuming that the pucks are used to protect the lower body panels from the arm of a hydraulic jack, with the end of the jack lifting the frame at a lift point...is that correct? The pucks aren't meant to be the lifting point, are they?
Is it guaranteed that if you jack the car with a hydraulic jack without using the pucks that you will damage your car?
Old 01-26-2007, 11:18 AM
Cobra2fastforu
Cobra2fastforu's Avatar
Old 01-26-2007, 11:25 AM
jbauch357
jbauch357's Avatar
Pucks are used as a spacer between the jack (or lifting arm) and the recessed portion of frame that sits higher than the rocker panel of your car. Typically without the pucks the lifting surface will press on the painted portion of your rocker panel, and not directly on the frame - this causing scratches or gouges in the paint. So yes, in this fashion the pucks are meant to be the lifting point.
I have been in some shops that use pucks and others that don't, really what matters is being careful when you lift the car. The shops that didn't use pucks used balled up rags and that distributed the weight enough to not cause scratches in the paint.
Instead of paying an exorbant amount of cash for fabbed up pucks that are aluminum I picked up 4 hockey pucks for a grand total of $8.
Old 01-26-2007, 11:31 AM
Husker67
Husker67's Avatar
The puck is placed on the jacks lifting pad. You then position the jack under the car at the lifting points and start lifting. The puck is between the jack and your car. And yes, you will scratch, dent or marr your car without pucks. IMHO
Old 01-26-2007, 11:35 AM
FactoryRaceCar
Support Corvetteforum!
FactoryRaceCar's Avatar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Pucks are meant to go and get secured in the shipping slots so that you could lift up your car without damaging the rockers.
Old 01-26-2007, 11:37 AM
wamara
wamara's Avatar
Cruise-In II Veteran
Pucks aren't there just to prevent scratches and gouges in the paint; the body panels could get cracked too.
Old 01-26-2007, 11:43 AM
Yello95
Yello95's Avatar
Received 1,227 Likes on 874 Posts
St. Jude Donor '11
The pucks go between the frame and top of jack....Rocker rails are a great solution so you don't have to use the pucks
Old 01-26-2007, 11:48 AM
1celtic1
1celtic1's Avatar
Default Not a "dumb" question at all...
I'm learning something here also....
Old 01-26-2007, 12:14 PM
OMG
OMG's Avatar
My lifting jack has a huge rubber "ball" on it so I don't need to use a jacking puck. It was only $60 at Sam's club.
However it is steel and quite heavy.
Old 01-26-2007, 01:11 PM
steve8
steve8's Avatar
I recently picked up 8 pucks also @ .99 ea @ Dicks sporting goods. They do the job fine.
Old 01-26-2007, 01:31 PM
Ruz
Ruz's Avatar
Different answers here...some say the pucks go in the shipping slots, some say they go between the jack lifting surface and the frame of the vehicle.
Old 01-26-2007, 01:37 PM
Herringchoker
Herringchoker's Avatar
Location: "Man been singin' the Blues, since he began to till the ground"...Vancouver, USA WA.
The space used for jacking pucks is tieDOWN point for shipping, if you look closely you will notice the slotted piece is only "spotwelded" to the inside/top of the tin panel and designed for DOWNforce. I've seen posts from members that have had the spotwelds break, and jackstands end up inside that area. Here's a better way, www.zo6vette.com "DYI- Lift your C5 without pucks" What ever you chose, don't forget wheel choks.
Old 01-26-2007, 01:40 PM
steve8
steve8's Avatar
That's really the same thing. If you have eye bolts in the hockey pucks, or if you buy the "real" ones, they go into the slots first, then the jack to the pucks. If you have just the pucks, the pucks would rest on the jack first as a spacer in between the jack and the car. It's still doing the same thing.
Old 01-26-2007, 01:49 PM
Ruz
Ruz's Avatar
I see the point now...talk about feeling like an ****. I would try to describe how I was picturing the whole thing, but then I would sound even more like a tool!
Thanks for all your help guys!
Old 01-26-2007, 01:57 PM
steve8
steve8's Avatar
No problem. I've said much dumber things than that!!
Old 01-26-2007, 01:59 PM
Herringchoker
We ALL have.
Old 01-27-2007, 01:04 PM
MagRed04C5
MagRed04C5's Avatar
Go to your local BMW dealer and ask to see their jacking pucks.
They clip into the shipping slots and stay there permanently.
You never have to think about them again.
At my local dealer they were $6 x 4 = $24 for piece of mind.
Old 01-27-2007, 01:24 PM
DoctorBrinkley
DoctorBrinkley's Avatar
My home made jacking pucks out of hockey pucks. I will later add pics of the frame slots like I should have. You slip them into the slots and turn them to lock them in.
Who said hockey is a worthless sport?
To Real stupid question about jacking pucks
Quick Reply: Real stupid question about jacking pucks
