HID Fogs are in...
Location: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
HID Fogs are in...
I got my Hella Micro DE's on Monday.. installed them Monday night...
THANK YOU TUAN LE (Supporting Vendor)... I ordered these Friday and they were here Monday!
Went from the PIAA's to these... wow... but mainly the beam pattern is noticeable. It's more focused with these, but it seems to go a lot further than the PIAA's used to...
Install wasn't harder than the PIAA's. I'm waiting on the other brackets to come, but in the meantime, I mated the OEM bracket (with a slight bend to fit) and the brackets that came with the Hellas.
Here are some pix as promised...
Dave
The length was not an issue... I believe it was only about an 1.5" longer..
View from top of engine bay, with headlight bezel removed... one bolt holds the light bracket in place.
Pivoting elbow made it a lot easier to get the one bolt out...
OEM bracket + Hella bracket
Here's the beam pattern prior to adjustments...
Dave
Night Owl for life
Received 3,247 Likes
hmmm...the beam pattern looks like it does not have a sharp, flat cutoff like HID lights usually do...t's very round the way regular bulbs output.
plus the color looks very yellow. this is really the HID kit with the ballasts and not the regular micro-de kit?
how sharp is the cutoff? i was assuming it would look like this:
I bought a pair of Hella Optilux fog lights, and I am waiting on them and the HID kit I bought to use with them. Is it illegal in most states to have HID xenon lights as fog lights?
Received 19,298 Likes
'20-'21-'22-'23-'24
Very nice.
Did you do a before pic with the PIAA's? That is what i have now and would like to compare.
Looking great! I'd been thinking of doing this, and will now pull the trigger after seeing this install.
Do you happen to know the part # for the brackets you used? I have a Z06 so no brackets at all.
Thanks, and a great job.
Ray
Ray
Thanks It's the OEM fog bracket... I don't have my service manuals with me, so I don't know the # off hand... sorry. Maybe Gene can shot them out to you.
