Front Ar Dam/Spoiler installation
I need to re install my center air dam. I cant see how this piece comes off... Does anyone have instructions????
Air Dam
Depends on if you are just installing the plastic piece or the entire metal brace.
Plastic piece is held on by 4 buttons with steel wires attached to them.
Push the buttons through the grommets in the plastic piece and then through the metal brace. Connect the two wires on each side with the springs. (Connect them together.)
To install the brace, there are bolts on either end that go into the front end protector bar. In the center, there are two aluminum brackets that bolt into the protector bar and then the brace is supported by them (but not bolted in so it can move slightly as needed.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
