technical reason behind staggered wheels?
Old 04-15-2007, 02:01 AM
mtm87tx
mtm87tx's Avatar
Default technical reason behind staggered wheels?
i hope i worded that right? i understand why you want a wider rear wheel than front but can someone explain to me why its a better design to have a smaller wheel in the front? like the stock 17/18 combo?
im buying new wheels and im between 18/19 and 19/19 and i dont know what advantage's there are to have a staggered combo?
thanks!
Old 04-15-2007, 02:11 AM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,910 Likes on 5,325 Posts
In the case of the C5/C6 it is about styling.
Bill
Old 04-15-2007, 02:13 AM
mtm87tx
mtm87tx's Avatar
Bill
so i will be fine with a 19/19 combo or does it look odd?
Old 04-15-2007, 04:00 AM
chuck1026
chuck1026's Avatar
Cruise-In II Veteran
That is as debatible as the "BSM vs. no BSM", "Auto vs. 6 speed", etc...
I went with a 18/19 setup with CCW. I personally like the staggered look. To me, the slightly bigger rear rim looks very cool.
There are lots of 19/19 guys on here too, even some 18/18's.
Look at more pix and make a decision. Meanwhile, here are some pix of mine .
Old 04-15-2007, 08:51 AM
KidCid
KidCid's Avatar
CI 7-8 Veteran
There is a slight technical reason but it can be compensated for. In order for the Active Handling to work correctly, the rear tires need to be slightly larger than the fronts. You can compensate for this with different profiles if you get the same size tires though. I ended up going wiht the 18/19 combo for that reason and I like the looks better.
Old 04-15-2007, 08:57 AM
Patches
Support Corvetteforum!
Patches's Avatar
I can think of a few possible reasons for a smaller wheel up front. Less mass makes for quicker turning response, less rolling resistance and better aerodynamics. Smaller wheel and tire are easier to fit within a smaller wheel well for packaging and styling purposes. The smaller combo could have made it easier to attain the difference in tire height needed for the traction control function. And, of course, smaller tire and wheel costs less. Here ais my 19/19 setup.
Old 04-15-2007, 09:10 AM
0EG@EnglandGreen
Supporting Tuner
EG@EnglandGreen's Avatar
Location: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
^ Ed, your car looks great!!!
jbondfl
jbondfl's Avatar
Location: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
I don't know of any real good technical reasons of why they went that way but the important thing now is that you keep the TIRE size differential. The wheel size now is more a matter of weight (smaller being lighter). I've seen a lot of photos with 17/18, 18/18, 18/19, 19/19 and usually it is more about the wheel style than the size. The only ones I really dislike (in the photos) are the 20's. Keep your tire diameter correct front and back and you won't have any problems with the TC or the AHS
Old 04-15-2007, 09:34 AM
rws.1
rws.1's Avatar
Actually a larger front wheel and smaller rear wheel diameter make technical sense.
Having larger front wheels permits lower aspect ratio front tires, with less sidewall flex, it gives better turn-in
Smaller diameter rear wheels permits higher aspect ratio rear tires, with more sidewall flex, it promotes better hook-up....
To technical reason behind staggered wheels?
Quick Reply: technical reason behind staggered wheels?
