GM Parts drilled/slotted rotors
Cruise-In IX Veteran
Any one have the drilled/slotted rotors from GM Parts Direct. I would assume they are not coated. only $53 each.
Location: Nation's Capital or the place that's known for TAXATION W/O REPRESENTATION
Had them on my 99 FRC not bad, but the hats rust. The remedy was Ecklers rotor hubs $150 for a set of four.
1 Post
New rotors might have some anti-rust coating on them, wash the hats with acetone or brake cleaner before painting them.
RonJ ...
Scientific Negotiator
Received 1,836 Likes
St. Jude Donor '07-'08-'10, '14
Go with the Napa's (non slot/drills). No better buy out there.
$26 for the fronts and $24 for the rears...
Paint and go!
Paint and go!
I use the 1200 (or 1600 if you can find it) Dupli-Color. Available at AutoZone or any of those stores. No primer needed, just a few coats (not too heavy).
Some of the exhaust spray stuff needs to be baked on. Great stuff, but the wife doesn't love me enough to let me bake the rotors in HER kitchen...
I bought the AC Delco Performance drilled/slotted rotors from Gene at GMPartsHouse.com. for $259.00 shipped. I used Dupli-Color 500 degree Engine Enamel "Clear" in a spray can from Auto Zone. Sprayed both sides of the rotors and wiped the brake pad sweep area with a lacquer thinner campened rag. No problems so far.
Mick
Mick
Mick
Mick
If you like the rotors and their not coated, some decent paint on the hats before you install them will keep them looking good. I brushed high gloss black Tremclad on the hats on my 01 a couple of years ago, still looking nice and crisp!!
RonJ ...
RonJ ...
Here's a link showing replacement of rotors w/Delco drilled and slotted rotors. The hats are painted w/hi-temp clear. After nearly two years they still look great. Paint has held up well.
http://dana60.com/rickko/corvette/rotor-rr.html
Good luck!
..rickko..
Good luck!
..rickko..
Good luck!
..rickko..
Good luck!
..rickko..
Zinc coated rotors look the nicest. No muss, no fuss!
When you wash the car the firepath gets an instant rust haze. But before I put it back in the garage, I coast backwards to the sidewalk and apply the brakes, drive foward into the garage with the brakes applied and No Rust!
Good luck!
..rickko..
Good luck!
..rickko..
