HUD Double Image
Old 04-22-2007, 11:53 AM
Barrier
Barrier's Avatar
Default HUD Double Image
From time to time there have been postings about HUD Double Image problems with non GM replacement Windshields. RED99 has suggested that the Pilkington Solar Windshield (non HUD model) seems to be at the root of this.
Does anybody else but RED99 have this problem with the Pilkington Windshield?
I have this windshield and was about to install the HUD when I heard of this.
Any comments would be appreciated.
Barrier
Old 04-22-2007, 12:11 PM
M6 Vetter
M6 Vetter's Avatar
Old 04-22-2007, 12:23 PM
Diceman9
Diceman9's Avatar
I am putting in a new shield this week. Not the one it should be for the HUD ($750 vs. $220). Don't know who makes it. I'll let you know how it goes......
Baaaaaa
Old 04-22-2007, 03:55 PM
FAAASTJEDI2000
FAAASTJEDI2000's Avatar
Baaaaaa
Why not the Hud proper wind shield? Is insurance not covering?
Old 04-22-2007, 03:57 PM
mph1972
Support Corvetteforum!
mph1972's Avatar
Cruise-In VIII Veteran
St. Jude Donor '07
Old 04-22-2007, 06:34 PM
Diceman9
Diceman9's Avatar
Nope no insurance this time. Cost about the same....
Old 04-23-2007, 07:48 AM
Barrier
Barrier's Avatar
ttt
Old 04-23-2007, 07:49 AM
Z064life
Z064life's Avatar
St. Jude Donor '06
Old 04-23-2007, 09:58 AM
Received 19,186 Likes on 13,910 Posts
'20-'21-'22-'23-'24
Not sure on this - others have reported using non-HUD windshields with no problem, but I don't recall them stating who made the windshield.
Old 04-23-2007, 10:30 AM
SilvaDragon
SilvaDragon's Avatar
I have a stock (factory) non-HUD windshield, and the HUD works
fine. I would expect this is the case with most who have non-HUD
windshields.
The issue would be if the windshield has some kind of coating on the
outside of the glass. The HUD works by reflecting off the *inner*
surface of the windshield. Normally, the A/C tint is on the inside,
and this actually works in your favor with the HUD.
If you introduce a coating on the outside of the glass that has a
high *inward* reflectivity index, then you could get two images,
one on the inside of the glass, and one on the inside of the outer
coating. Due to the angle of the windshield, these two reflections
will be offset by a distance equal to the thickness of the glass
and, voila! - double images.
So, if you can just get the stock GM glass, you should be good to
go. If you get cheap aftermarket glass (or expensive aftermarket
glass with an extra "special" coating), well, that's what you get...
Old 04-23-2007, 12:17 PM
Barrier
Barrier's Avatar
Default Pilkington Solar non-HUD Windshield Double Image
My '99 already has the Pilkington Solar. When the last posting on double image came up I asked RED99 (he started the post) which brand he had. He checked and found it to be the Pilkington Solar. Since there were posts on this before I am trying to find a connection. I have not installed the HUD as yet.
My windshield was replaced before I owned the car due to Stone Chips. I thought that it didn't really matter if the non HUD was used since most posts reported there was no difference. There were reports of Double Image but very few, I never thought the Maker of the glass would have mattered. I still am not sure, that's why I am asking.
Barrier
Old 04-23-2007, 12:22 PM
Diceman9
Diceman9's Avatar
My research indicated that a stock windshield may show the double image. However, on a vert or Z06 the shield is thinner... thus not showing the double as well. There are 2 surfaces inside and out. I dunno...... I will see soon.
Baaaaaa
Old 04-23-2007, 08:13 PM
Barrier
Barrier's Avatar
ttt
Old 04-23-2007, 08:20 PM
Mike Mercury
Mike Mercury's Avatar
I have seen pics of the "double image" problem - and yes, it seems to always come down to a non-factory windshield.... that got replaced once before the current owner purchased the car.
Old 04-24-2007, 08:42 AM
Barrier
Barrier's Avatar
ttt
Old 04-25-2007, 08:54 AM
Barrier
Barrier's Avatar
Anybody else have the Pilkington Solar non HUD windshield??
Barrier
Old 04-26-2007, 09:04 AM
Barrier
Barrier's Avatar
ttt
To HUD Double Image
Old 04-28-2007, 11:37 AM
Diceman9
Diceman9's Avatar
Baaaa....
Old 04-28-2007, 02:31 PM
Mick_C5
Mick_C5's Avatar
my question is why is there a hud windshield if most glass will do?
Old 04-29-2007, 08:48 AM
Diceman9
Diceman9's Avatar
Ok.... got the w/s in on saturday.....was worried about the HUD not working or being blurry..
Safelite put the shield in. I didn't get the $700 one went for the $225 glass. Turns out they put in a "DW 1430". This glass is the OEM for the Z06. Even has HUD stamped on it. HUD works just like before. Don't know if they screwed up or what. But got excellent service at a great price!!
All is good.
Baaaa.....
Quick Reply: HUD Double Image
