NAPA gold oil filter increased my oil pressure (question)
The pressure went from 38 to 44 at idle and cruising speed. Is the increased pressure a good thing? And does the NAPA oil filter have less filtration abilty that a filter that does not increase pressure
I can't answer any of those questions. I do know that WIX makes the filters for NAPA and Carquest...maybe you could broaden your search questions to WIX for some more accurate answers
My understanding is that pressure goes up as flow goes down and filtration goes up... ie a better filter increases back pressure.
Therefore it appears that your NAPA Filter has decreased flow and increased filtration. That is probably good for engine life, unless your race when maximizing flow is more important
Received 1,674 Likes
I have noticed that oil pressure does go up for a while after a oil and filter change.
What oil (including viscosity) were you using before and after the change?? Was it dino or synthetic?
Yes and no. A better filter will increase backpressure, but oil pressure in a car engine is measured downstream from the filter. So when you increase backpressure you are actually reducing main oil pressure. If you put in an empty filter cartridge you would get very high oil pressure, but no filtering.
So, what should one conclude regarding filtering of these "better" filters (Mobil 1 in my case) that do increase pressure?
I've never seen any good, scientific testing of oil filters (or air filters for that matter). Each manufacturer just says theirs are the best; "long life", "better filtering", "better engine protection", and other useless information. If anyone is aware of any testing, please let me know, I'd like to take a look at it.
I switched from a K&N oil filter to a Wix filter (which is an identical filter to NAPA Gold) on my last oil change (in the fall) and did not notice any change in oil pressure whatsoever. The K&N is generally regarded as one of the highest flowing filters too.
I have been using DELCO Gold oil filters, they filter great but do not flow well. I recently changed to NAPA Gold (same filter as WIX), and my oil pressure increased. I think this shows increased flow.
Most people say that WIX filters are good filters. They have metal contruction and a large pleated filter. Only bad thing I have heard about them is that there is no rubber/silicone seal for the high-pressure bypass (just metal to metal), so it probably leaks a little all the time.
One shouldn't generalize by saying that higher oil pressure equals better filtration. Some of the best coalescing filters out there can filter oil from airflow incredibly well, yet produce very minimal pressure drop.
By the same token, a really good oil filter will not only filter well, but produce little pressure drop. Back a few years ago, bobistheoilguy.com tested many oil filters and found a few to represent very good combinations of filtering ability and low pressure drop. Among them was the K&N filter. Patman has used this filter before more than one oil analysis and his results always showed that the filter was doing its job well.
Based upon his results and the bobistheoilguy.com tests, I have been using K&N oil filters in my C5 for quite a while now.
Oil filter relocation....
In this vein of oil filter questioning.... What about relocating the oil filter. I was thinking of moving it up into the engine compartment. The oil may be good for 10k miles, but changing out the filter a couple of times in that interval surely must be benificial to oil and engine life.
Comments...............
DJ
DJ
Most people say that WIX filters are good filters. They have metal contruction and a large pleated filter. Only bad think I have heard about them is that there is no rubber/silicone seal for the high-pressure bypass (just metal to metal), so it probably leaks a little all the time.
There is no bypass valve in the oil filters for our C5s, the bypass valve is built into the oil filter mount on our engine block.
They do have an antidrainback valve on them though, and they use the better silicone one (vs nitrile) which is more durable for hot/cold extremes.
DJ
DJ
One added question to my oil filter question. I know oil change intervals have been talked about before on here, but wandering if I should go by the oil % life left or how long I has been in there. It has been 2 years (2 summers) on the oil and filter and only 5000 miles. Should I have waited? I sure feel better changing it. Last oil change was AC filter and 5w30 Mobil 1.
