What is the correct rake for C5 Z06
1 Post
Have been doin a few spirited runs and am gettin alittle loose it feels like. Thinking maybe I don't have the appropriate rake causing this problem.
CI 3-5-6-7-8 Veteran
Front shold be 5mm lower when measured at the jacking puck holes in the fram rails.
Most on here jus slam the back down low w/o reguard for the reake.
If the car feels odd it's most likely allignment related and/or tire pressures. If you don't hvae enough front caster the car will feel like a sloppy pig.
1 Post
Tell them what you want... for a street car I'd recommend the max oem Z06 settings.
Most dealers use a range which is BS for a sports car... you want a specific number.
I agree! A lightweight car like the Z with really wide tires is affected a great deal by very small changes in the alignment. Tell them EXACTLY what you want, and if they can't get that for you go to someone who can.
