Chrome Trim Pieces
Received 1,675 Likes
1 Post
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
I don't think I've seen a trim ring for the taillights, or for the side markers either. I guess you could buy a cheap set with louvers, cut the louvers off, then have the remaining ring chromed?
If you want side marker trim, tail light trim and stainless letters for the front and back, go to ebay and check item # 110041122225. If you want to trick out your engine compartment, check out my avatar. That came form EastCoastCorvettes. Look under engine dress up kits.
