Catch Can Effectiveness - PART TWO w/PICS
Old 05-19-2007, 07:24 PM
Paulg680
Paulg680's Avatar
CI 7-8-9 & 12 Veteran
Wounded Warrior Escort '11
Default Catch Can Effectiveness - PART TWO w/PICS
Recently I posted a pic to show how much oil was captured by my new Elite Engineering Catch Can. The first photo shows the amount of oil after about 600 freeway miles and four 20-minute sessions on a road course.
Here's what I found after two more weeks of normal driving (cruising to/from work - No freeway miles). Although it was less than what I found the first time, it's still more than I expected. These things work!
Old 05-19-2007, 07:33 PM
BUBBAS 01Z06
BUBBAS 01Z06's Avatar
Can you explain the significance of the catch can ?? Where is all that oil coming from ?
Dumb question I know...but Im sure someone else is wondering the same thing.....
Old 05-19-2007, 07:37 PM
M6 Vetter
M6 Vetter's Avatar
They sure do
Old 05-19-2007, 07:48 PM
Paulg680
Paulg680's Avatar
As part of the Positive Crankcase Ventilation (PCV) system, there is a hose that vents vapors from the valve cover area directly to the intake. The catch can is a very simple device that has a type of heavy steel wool that allows the oil to condense and collect in the catch can. The vapors pass through and are dumped into the intake minus most of the oil.
Check out the Elite Engineering website. They have a more detailed explanation of how they work.
Old 05-19-2007, 07:49 PM
mph1972
Support Corvetteforum!
mph1972's Avatar
Cruise-In VIII Veteran
St. Jude Donor '07
Great little preventive measure!
What does the CATCH CAN do? Helps prevent oil that travels through your PCV system from getting into your air intake manifold. Over time, it will cause problems (oil in the intake).
Old 05-19-2007, 07:52 PM
BUBBAS 01Z06
Thanks !
Old 05-19-2007, 07:58 PM
Dave68
Dave68's Avatar
I'm glad you asked. Here is an article I wrote, a short while ago. It explains how your PCV valve works and what is the best way to "catch" the oil that normally gets into your intake manifold.
http://www.conceptualpolymer.com/PCV...oval%20101.pdf
Dave
Old 05-19-2007, 08:07 PM
mph1972
mph1972's Avatar
St. Jude Donor '07
Dave
Old 05-19-2007, 11:12 PM
Rob 99
I'm "Apache" a psycho dog
Rob 99's Avatar
Here's mine after i actually forgot to check it for a time,with 2 dyno pulls and some street sessions for tuning and normal daily driving i almost spilled it taking it out never expecting to see so much about
2/3's full
[IMG][/IMG]
Old 05-19-2007, 11:17 PM
Paulg680
Paulg680's Avatar
2/3's full
[IMG][/IMG]
Wow! That's a LOT of oil!
Old 05-19-2007, 11:20 PM
SpeedUp
SpeedUp's Avatar
2/3's full
[IMG][/IMG]
OMFG!!
Old 05-19-2007, 11:25 PM
Received 19,188 Likes on 13,911 Posts
'20-'21-'22-'23-'24
Amazing how much oil they catch.
Old 05-19-2007, 11:28 PM
B-rent
B-rent's Avatar
Wow I need to install mine, just gotta find a place to mount the catch can cause the location advertised is taken up but my S/C components
Old 05-19-2007, 11:32 PM
Paulg680
Paulg680's Avatar
I'm interested to see if a S/C car results in a greater amount of oil accumulation or not. Let us know what you find...
Old 05-19-2007, 11:56 PM
B-rent
B-rent's Avatar
Haha now Im starting to get motivation to put it on i sure will
Old 05-20-2007, 12:20 AM
2klude
2klude's Avatar
You probably break the record for most oil in a catch can
Old 05-20-2007, 12:47 AM
MUKAK
MUKAK's Avatar
To Catch Can Effectiveness - PART TWO w/PICS
Old 05-20-2007, 01:23 AM
JETZ
JETZ's Avatar
Just ordered mine last week!
Old 05-20-2007, 05:58 AM
DevilDog II
DevilDog II's Avatar
Oldtimer
I just put mine on yesterday. I'll keep you posted.
Old 05-20-2007, 06:32 AM
DeeGee
DeeGee's Avatar
I just drained mine this morning. Quite a healthy catch
Quick Reply: Catch Can Effectiveness - PART TWO w/PICS
