I meant how much would it be to rebuild the ENGINE.
Depending who does the work will make the qoute more or less. The type of re-build will too. A higher compression, nice internals will run alot more then say a budget build.
If your looking for a nice N/A setup, you could do a 4" crank to make a 382ci along with decent heads and a cam to make pretty good hp without using a power adder.
For example a stock crank rebuild (347ci) we charge $5700 inc labor/tune/break-in/R&R the motor .
