Wheel Hop w/ProGold Luk Clutch????
I had a new ProGOld Luk clutch w/Alum flywheel installed in 99 vert a few months ago and now I am experiencing wheel hop. Anyone had any experience with wheel hop and the Pro gold w/Alum flywheel? Never happened before with two different stock clutches........
vert
vert
The only connection these upgrades could have to your wheel hop is how much HP and torque is now getting to the wheels/tires. Now that you are able to really put force on the tires they are starting to hop. Upgrade your suspension and you'll be better off.
CI 3-5-6-7-8 Veteran
You're getting wheel hop because w/ the more aggressive gearing of the MN12 and the aluminum flywheel the car is accelerating much faster w/ the samer power from the motor.
Thus you're getting hop... you need to mess w/ the suspension.
