Side marker light
St. Jude Donor '07
Remove rear tail light , reach in and twist the plastic holder at the end of the wire connector, pull out light .Light type is 194.
St. Jude Donor '07
Ok front driver side it is. Use a jacking puck to lift up the front driver side. Just in front of the tire towards the nose of the car , you will see an access panel. Remove the bolts and you will see the plastic housing for the side marker lights/ DRLs/ turn signals. . The smaller of the two plugs is the one you want. It too is a 194 bulb.
