iPod2car/iSimple question
Those of you who have this, when you got it did you install it yourself or have someone install it for you?
If you installed it yourself, how hard was it to install?
If you had someone install it for you, how much did it cost and where?
Cruise-In VIII Veteran
St. Jude Donor '07
I installed the ipod2car in my car. I had the CD changer, so I needed a specific cord (GM4 cable - do a search and you will find the exact number of the cable). It really wasn't that hard, took about 10 minutes to take my center console off (I have done it a few times, maybe a little longer, if it is your first time.). Two screws and the head unit was out and unplugged the cord and plugged the new one in. Make sure that your box and cable aren't touching anything hot, that will screw things up for you. Don't ask me how I know.
Micah
Micah
Micah
Micah
I have a lengthy discussion thread going on about that right now. See the last page. I just received an extra PXHGM4 cable that I will sell at cost, but you must reply in that thread as I offered it there.
http://forums.corvetteforum.com/show....php?t=1752127
St. Jude Donor '07
- Make sure you have the extra cable if your car does not have a CD changer.
- Get some velcro strips or zip-ties before you start. You will want a way to make sure the box doesn't rattle about in the space behind the head unit.
Here's one description of how to get the console off and gain access to the radio. https://www.corvetteforum.com/techti...D=87&TopicID=1
Lots of more information on the other thread.
I agree with everyone else, make sure you have the extra cable before you start. Best Buy said I was good to go but I needed the GM4 cable. Fairly straight forward to install. Print off the step-by-step directions of how to remove waterfall, console, etc. My car is very stock but this has to be the best mod I have done. I took some time trying to decide where to actually put the Ipod. I initially tried the glovebox but I decided I like using the Ipod controls better than using the head unit. I finally use the included mount to put it on the center air conditioning vent. I routed the cable up through the dash. If you have an questions please PM me. Thanks
