A Better Backup Bulb?
I hate the sickly yellow look of my backup lights, so I bought some 18 LED replacements bulbs, which look great, but only put out around 75% of the light. Has anyone found a pure white backup bulb that is at least "as bright" as OEM?
BTW: I don't want to pay the $$$ for the "diamond" cut backup assembly.
Warning
I posted this a week or so but be careful of those 50 watt halogen bulbs advertised. I installed a pair and it wasn't a week and one had burned out. When I tried to get it out, it had "welded" itself to the housing. After much cussing and a soldering gun it came out. I replaced it and upon checking to make sure they worked.....by the time I got around to the rear (turned on the ignition) it had started to burn a hole in the plastic housing! I put the 1157's back in and returned the halogen's.
I assume that there's got to be a brighter, cleaner light that stays in the 35 watt range.
I have the diamond cut back up/ license plate holder and the standard bulb is very bright. Cost more than bulbs but looks great. It's made by Ajure (sp) and Forum vendors sell them.
I like the Adjure unit too but way too expensive. If I could just figure a way to get the OEM housing open (safely) I would get the inside chrome plated. MUCH greater reflectivity and would greatly improve the light output onto the ground.
St. Jude Donor '06-'07-'08-'09
Richard
Don't get me wrong Richard, I think the diamond cut looks cool and I'm always watching "parts for sale" to pick one up on the cheap. I just don't want to spend the money. I already bought the $32 LEDs which I think look great, but I found that with the standard housing, just were not as effective as the crappy OEM bulbs.
Basically I'm looking for a $50 or less solution.
On the other hand, I am the ultimate impulse buyer, so you may see an order from me next week, you never know.
hi here in the uk you have to have rear fog lights,so i mounted mine where the back up light bulbs where.i then drilled two small holes above
those bulbs,and placed 2 small blue halogen bulbs in,there bright.
and yeah the diamond back up assembly aint cheap but i love it.
when`s yer birthday ...you could try and put 2 of these blue bulbs in each lamp ,got em from autozone on holiday.
you can just see them in the b/up lamp housing..nitro uk
Richard
I've dealt with you before and know you stand behind your products. I bought these LEDs from autolumination.com. (I love LED's, I'll find a use for them. )
Former Vendor
St. Jude Donor '08
amperage draw could be solved with a relay if you really need tha much brightness, and the plastic is the same plastic used in most headlight housings. Since the bulb mount has a plastic mount, i wouldnt' be concerned about melting much. I may just give this a try and see if it will even fit.
I got the high powered 1157-LX3 Luxeon LED bulbs from www.superbrightleds.com
They are just about as bright as the oem bulbs
Richard
Former Vendor
St. Jude Donor '08
Porjectors wouldn't be a bad idea...although it's unlikly to see them from the factory meaning there would be custom work involved. HID kits would pretty much be pointless considering the "charge" time and the expense of using them for about 30 seconds at the most any given night.
Well, without using the Adjure Clear back up lens, I almost positive that you won't be able to make it any more brighter than what it already is- even when using LED's -because the whitish tint on the OEM lens cuts part of the light out. I have the Adjure back up lens
and then I bought some Sylvannia Silverstars for the bulbs, although it now gives an amber illumination - it is brighter than the clear regular back up bulbs!
Former Vendor
St. Jude Donor '08
this is why auxillary back up lights are so popular among truck owners. At one point I was thinking of mounting a set of them inside the rear facia vents. I think GM decided to do this properly with the C6.
