ZO6 Shocks on C5, may have to go......
Put a set of ZO6 shocks on my C5 today, car ride height doesn't seem to want to settle out( stock height, car isn't lowered) and ride is MUCH harsher than I would have ever expected. These are used 2003-04 shocks 7k to 8k mile on them. Difference in size of shock was obvious but shouldn't the ride height return to what it was and is the Z06 shock really like driving a 4x4 vs. my C5 shocks. Daily driver and weekend backroad fun time but these may have to come off.
I really didn't expect them to be this harsh.Just the same stay tuned for a possible sale since this is my daily driver.
C5 General
Location: Boosted in Manhattan & Round Rock TX. President of the Non Club Club of Kansas and Round Rock , Not the flat part.
I went w/ 07 Zo6 shocks on my lowered Z51 97. The ride is pretty good.
The frunt came up some so I lowered ont down some more. Over all im happy.
Paul G.
Paul G.
Will the car settle, I didn't drive it but a few miles.
I wonder if the harshness is due to the fact that those shocks are not tuned to match your springs? My '02 Z06 feels surprisingly soft to me. I'm using the 2004 Z06 shocks.
However, we all know that everyone has different tolerance for ride harshness, vibration levels, etc.
I have read a lot of shock absorber reviews/opinions. It sounds like you might like the Koni FSD shocks (>$630) or the Bilstein Heavy Duty shocks (>$300).
St. Jude Donor '07
Harshness and ride height problems are caused by "stiction" a tendency of the shock to stay in place when it rebounds up. It will go away after a couple of hundred miles. I went back roads banging in my car for about 50 miles, when I came back, my car dropped 1/2". Give it time, they'll settle in.
John
John
John
John
Just in case you dont know, there a procedure to lowering the car. Its not just turning the bolts. You need to relive pressure off the spring then the bolt will turn. I would just drive the car around for a week or so, get the shocks to settle in & see what it does.
Try lowering it before you remove the shocks!
If you get rid of them you might pick-up a set of C5 Z51 Shocks!
It's what I'm running on my '98 with C6 Z51 sway bars, it = Awesome Ride - and lowered all the way around!
Thanks,Matt
Thanks,Matt
Harsh is so subjective...
I had a lowered Camaro wirth G2 springs and Koni's shocks which I thought was "Firm" but after driving my ZO6...which is supposta' have firm shocks.....the Camaro was harsh...
morel...One mans firm is another's harsh
I didn't get too aggressive,was concerned about stripping or snapping them.
Thanks Matt I may end up going that way. Beautiful ride,love your show!
The threads are not reverse thread, but it can seem that way if you don't orient yourself in relationship to the bolt. It's easy to think that when you're under the car. One member recently posted images of oem bolts showing RH thread, not LH thread as in reverse thread.
Here's a prior thread which has images of the RH 10mm front bolts...
http://forums.corvetteforum.com/show....php?t=1750050
Mine are C5 Z06 and I haven't given up yet, just rather perplexed as to the characteristics of the shocks. I'll run them for a couple hundred miles this weekend and then decide if I go back and just get a new set of standard C5 shocks to put back on or keep these.
Can you use the C6Z06 shocks on the C5 if it is lowered on stock bolts?
I only ask because it was listed on someones site next to the C6Z shocks and the price, that it was not recommended for C5s that are lowered. Maybe it was Gmpartsdirect or whoever lists the occasional specials on factory parts.
