CB Antenna Mounting?
I've searched the forum for cb, cb antenna, and "cb antenna" and come up empty.
How do you mount your CB antenna? Obviously you can't use a magnetic mount.
I've seen the mount that fits behind the license plate. Where does a person get one of those?
Any other suggestions?
TIA
TIA
Most guys fit sat antennas in the rear space inside the fender. Take out the rear T/S light on the right and you'll see the options.
Look at some of the supporting vendors like ZIP, MID-AMERICA, PFYC or CORVETTE CENTRAL...one of them has a CB mount, but I can't recall which one.
I'd think a CB antenna would need as much height as possible to give optimal reception, just like a regular radio mast.
Go to the main menu, scroll down to the forum dedicated to stereo discussions, one of them might know.
Hi Craig -
I have the license plate mount on my Z - and I can get out 3-4 miles with my Midland handheld unit and the setup I have.
Here is the license plate mount kit:
http://www.rivercitycorvettes.org/harris_mfg.htm
Here is a link to some alternatives -
http://www.koolkatcorvetteproducts.com/photo.html
Here is the NGP Firestick antenna that I have - making a license plate mount is an easy task - mine is made of plexiglas.
http://www.westcoastmall.net/firesti...it-black/215/p
best regards -
mqqn
best regards -
mqqn
I don't have one but think this would be a good solution
Designed specifically for the C4 and C5 Corvettes, this CB Antenna System matches both the beauty and performance of your Corvette. The tunable tip antenna permits transmission and reception from farther distances, while the quick disconnect system allows you to easily detach the antenna any time. This state of the art No Ground Plane (NGP) kit includes: NGP coax cable, NGP 3' antenna mast, and low profile polished stainless steel mounting plate. The antenna mast is available in red, white, or black. White may be painted to match your Corvette exterior. All units use existing license plate mounting holes with some drilling required. Arrives with detailed installation instructions. Please specify antenna mast color.
Available from Mid America.
I also wonder how many people here will take any notice of the new law here in CA? Nobody seems to take any notice of the Stop signs or the 4-Way Stops here so why would they put their cell phones down I live by the beach and the signs are known as "Stoptional" signs!
Slight
Tap
On
Pedal
10-4 good buddy I used to own a CB when I was living in England and found it useful on the M25 but don't know how useful a CB would be here!
Not a problem nowadays. Radio signals don't make it as far as Lincolnshire
Craig:
This is the set-up I have on my 02 vert. http://www.rivercitycorvettes.org/harris_mfg.htm
I was a member of River City before I moved up here. It is very well made and hides the cable. Give me a call and you can look at mine.
Randy
Randy
I wouldn't think it would be hard to fabricate the bracket once you decide where to mount it. Any CB antenna should work on your DIY bracket.
TIA
TIA
I've used the koolkat antenna, which sits inside the car and hides your antenna farm from John Law.
1 Post
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
I have this one also and it works great - no need to hang one outside the car!!
