Non Run Flat tire flats.
I had 2 flats in 2 days las weekend with my GSD-3s. 1st one was a slow leak and was able to use compressor to put air in tire and make it to tire shop to get it plugged. 2nd one was a fast leak with a very large nail through the side wall. I used the Continental ContiComfort Kit with the sealer and it worked like a champ. Local tire shop changed the tire, cleaned the tire pressure monitor and eveything is working great.
I have ZO-6 wheels with Goodyear Supercar (non-RF) tires on my 2000 FRC. I installed new sensors to be able to monitor tire pressures and hopefully get some warning of a slow leak.
A while back I was pulling out of the drive and got a low pressure warning with 19# indicating in one of the tires. I checked the pressure with a gage and verified it was low. When I checked the tire it had a nail in the center of the tread. I repaired the tire with a plug/patch after removing the tire from the rim and it has been fine for more than a year.
I also have a spare tire from an 05 GTO for trips as a back-up, along with the ZO-6 kit which I carry all of the time. Keep in mind that most leaks are slow leaks caused by a nail in the tread. With a bit of early warning from your TPMS, you should be able to deal with most of them in a non-emergency manner, for everything else there's MASTER-CARD ... ( just kidding of course).
Good luck...GUSTO
Good luck...GUSTO
Thanks for the info.
